Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Unread 19-01-2011, 09:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Pressing Pinion onto Banebot RS775
Originally Posted by Paul Copioli View Post
The RS775 shaft is definitely 5mm. The motor mounting holes are M4. The shaft has a negative tolerance as most of our motors have a shaft diameter of 4.95 mm.
We have successfully taken the FP pinion from the AndyMark Fisher Price transmissions and modified them for use on the RS775. We also have modified the AM Planetary motor plate to receive the RS775 for use in the AM Planetary. It works great.
We are match drilling and reaming every pinion to every shaft. We had to purchase a new reamer. I will find out which one we are using today and get back to you.
Paul
It really works to drill and ream the FP pinion? It's not too hard?
