Go to Post We're all such geeks...not that's that a bad thing. - IMDWalrus [more]
Unread 19-01-2011, 11:01
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: WindRiver connection problem on Tablet Computers?
Originally Posted by Bot190 View Post
If my interpretation of what the OP or nolanpoe, said in his first post is correct, the dialog boxes didn't have any place to enter info. They probably looked like this:
Where the dialogs are completely missing. Whereas in the 6th post, the screenshot showed the boxes for input.
I think you are probably correct -- my mistake.
I thought post #6 was just a reiteration and elaboration on the original post.
The VM using 32-bit OS seems to be the only 100% reliable solution available to those using 64-bit OS.
And finally, there clearly was some confusion in post #6 that needed to be cleared up -- the empty (as opposed to missing) fields was not a problem.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
