Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
Unread 18-01-2011, 20:56
Trevor1743 Trevor1743 is offline
FRC #1743
Trevor1743 is an unknown quantity at this point
Gearing Window Motor?
Does anyone know how to get gear up a window motor? We want to take it from 84 rpm to 756 rpm, A 1:9 increase.
Specifically where would you get the gears?
Unread 18-01-2011, 21:13
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Gearing Window Motor?
What is it for? Gearing the Denso window motor up 1:9 will result in very little output torque.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-01-2011, 21:17
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Oh my, that would move something very light very fast. What are you going to do?
Anyway, I would recommend using chain and sprockets, easier than gears in my opinion.
Go REX!!!
Unread 18-01-2011, 21:23
FRC #1743
A roller arm for picking up the tubes.
Are their sprockets made for the Denso output?
Unread 18-01-2011, 21:44
artdutra04's Avatar
You can either modify the plastic output hub that comes with the Kit of Parts (we've drilled the 6x Ø1.875 "standard hole pattern" into them before to mount AndyMark sprockets onto), or you can machine an identical hub into existing gears or sprockets.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-01-2011, 22:19
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The premade Denso sprockets are "Coupler, Denso motor" as listed in the KoP checklist. Perhaps you could rig something to that?
Unread 19-01-2011, 11:56
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Belts, gears or sprockets......
If you want it light as possible, I'd use the gears from the FP transmission, and belts.
Unread 19-01-2011, 14:49
Generator of Entropy
FRC #2973 (The Mad Rockers)
If you want to make your own gearbox, you could make two 3:1 sets; I'll use the Tetrix gears as an example - SDP-SI.com has a good selection of spur gears to use. Mount a 120 tooth gear to the motor output adapter, attach a 40 tooth gear to another 120 tooth gear and mount it 2.5 inches away, then attach a 40 tooth gear to your output on the same axis as the motor output shaft (doesn't have to be on the same axis but it simplifies the housing).
