Go to Post Don't take my questions negatively, I just hold drive trains to a ridiculous standard. - AdamHeard [more]
Unread 19-01-2011, 06:31
Nazir Laureano Nazir Laureano is offline
FRC #1382
Nazir Laureano is an unknown quantity at this point
pic: What about this???
Unread 19-01-2011, 06:34
Guilherme R.'s Avatar
Guilherme R. Guilherme R. is offline
FRC #1382 (ETEP Team)
Team Role: Electrical
Guilherme R. is an unknown quantity at this point
Re: pic: What about this???
3/8" would be awesome, it should stand a big hit, shouldn't it ?
Unread 19-01-2011, 07:16
bruno1308 bruno1308 is offline
FRC #1382
bruno1308 is an unknown quantity at this point
This is really good! That's an amazing drawing. The size of the plates maybe 3/8", you are right Guilherme. Good luck, see you at the competition!
Unread 19-01-2011, 07:20
Igor1201's Avatar
Igor1201 Igor1201 is offline
Igor1201 is an unknown quantity at this point
I don't think so, I think the better is 1/2" of size, this may be perfect. But this a amazing job! good luck to u all
@Team1382
Unread 19-01-2011, 07:24
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
My team did 1/4" last year and it was overkill. 3/8" is even more than you need. If you get some cross supports between the side plates and support it from the inside then you could go with 1/8 inch. Make sure to cut out some of the weight in structurally insignificant points in the metal, otherwise this could be very heavy and take away from other subsystems of the robot.
Unread 19-01-2011, 09:00
Brandon Holley's Avatar
Originally Posted by Nazir Laureano View Post
I'm glad to see you are all proud of your own team's work....
1/4" plate will be plenty. I would start worrying about weight in its current configuration. Keep up the good work.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-01-2011, 09:02
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
1/4" should be the absolute max thickness of your sideplates, and thats way overkill. With proper breaking theres no reason you can't go a 10 or 11 gauge aluminum.
Unread 19-01-2011, 12:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
What material are you making it from? If it is aluminum, then 1/8" would be good. If it is plywood, then 1/2" or 3/4" would be good.
Think about how heavy the robot will be, include ALL the parts.
Unread 19-01-2011, 12:20
Chris is me's Avatar
AKA: Pinecone
I would step down to 1/8" (except for the L brackets) and then use plenty of standoffs to make a more rigid robot. Make the drive axles double as standoffs, put some in between the wheels... just add some and you'll have a lot less problems. Don't forget cross bracing between the two sides.
I would see if you could make your chassis shorter. Why all that height? That's just more material and more weight.
Are you able to cold roll flanges into sheet metal (do you have a brake)? If so, they will dramatically improve your resistance to bending.
Unread 19-01-2011, 14:23
FRC #1382
Our is made of alluminium, but I don't know the size of this. Please, Help us!!!
Is better we stop of this plan and start other one??? And what about the weight of this
Unread 19-01-2011, 14:27
FRC #1382
Is better we stop of this plan and start other one??? And what about the weight of this???
And about the height, we are using all this height because it is more easy to the project of minibot and the arm for the game pieces.
Unread 19-01-2011, 15:43
By the looks of it, it appears you are using 1/4" aluminum plate (I may be wrong).
With the height of the drive base, the amount of plates, and lack of pocketing to save weight, this will be a very heavy drive base. You can fix this by making the drive base shorter, switching to a thinner wall aluminum plate and adding standoffs, or pocketing the drive plates so they weigh less.
I would talk with your team about weight budgets, and try to give yourselves a weight estimate for each subsystem and see if your current configuration will fit into the drivebase's weight allotment.
Also as a sidenote, this is in CAD so you should be able to get a weight estimate right in the CAD software to let you know approximately how heavy it will be.
Good luck, feel free to ask any other questions you may have, I'm sure many others can help as well.
-Brando
