Go to Post Simply. Minimize. Reduce. It's a good engineering rule, and an even better management one. - Tom Line [more]
Unread 18-01-2011, 15:44
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
Logitech Dual Action Setup for 2 Axis help please?
Hey, im kinda new to FRC java and i need assitance in making a basic drive program that will work 2 joysticks on 1 controller. How would i set it up correctly?
1793 FTW
Unread 18-01-2011, 16:34
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: Logitech Dual Action Setup for 2 Axis help please?
You mean like tank drive on an Xbox or PS3 controller, right? I'd assume you'd use it like any joystick. Define it on whatever USB port and you should be set.
There's also a pretty good post about something like this here. (and VIA link from that thread here, too)
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 18-01-2011, 22:16
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
You just declare it like any ordinary joystick, and read each axis from each joystick independantly. One stick will be axis 1 and 2, the other will be 3 and 4 (Unless there are other analog inputs). Also, make sure the DS has the proper drivers!
Unread 19-01-2011, 12:58
robotic321's Avatar
FRC #1793
alright, but how would i declare it? This is the way i thought it could work itself :
Joystick joy1 = new Joystick(1);
But, how would i refer to the axis number that i desire and not have it get a heart attack (stay away literal types (_v)
1793 FTW
Unread 19-01-2011, 18:34
Originally Posted by Jared341 View Post
Axis indexes:
1 - LeftX
2 - LeftY
3 - Triggers (Each trigger = 0 to 1, axis value = right - left)
4 - RightX
5 - RightY
6 - DPad Left/Right
Button mapping matches Windows Control Panel>Game Pads display
To read an axis (like the left stick Y axis), simply do:
double axisValue = mXboxController.getRawAxis(2); // Where "2" is the index of the Y axis on the left stick (see above)
sums it up quite nicely.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 20-01-2011, 22:07
FRC #1700
Yes, thats exactly how to do it. As Robby Unruh said, you would them call
joy1.getRawAxis(1)
to get the value of the first axis, and you would use the proper index from the list that Robby Unruh posted. For a two sided drive system, I believe you would want 2 and 5.
Unread 23-01-2011, 16:15
wjbrauck wjbrauck is offline
Team Mentor
FRC #0768 (Techno Warriors)
wjbrauck is an unknown quantity at this point
We just modified last years code yesterday to get this working. We found axis mapping to be
Axis indexes:
1 - Left joystick X
2 - Left joystick Y
3 - Right joystick X
4 - Right joystick Y
5 - DPad x
6 - DPad y
to stay with tank drive and use both joysticks from one game pad plugged into USB port 1, the code looked like
in the constructor
m_driveStick = new Joystick(1);
in the teleop section
m_robotDrive.tankDrive(m_driveStick, 4, m_driveStick, 2);
where 4 and 2 are the axis numbers assigned to the left and right joystick arguments.
wjb
Unread 24-01-2011, 08:07
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
in these examples what would have to be imported in order for these to be used?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 24-01-2011, 19:08
In my code I usually just use:
import edu.wpi.first.wpilibj.*;
so it imports everything. But for Joystick's it's just:
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
