Go to Post (The wheels) need to be green anodized, and then assembled with yellow anodized spinners. ... and then, on the spinners, you can etch "JVN is a dweeb". That would be cool. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 19-01-2011, 14:20
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
[C++] CAN cRio image problem
After updating all of the jaguars and the cRio with the black firmware option, our cRio freezes right after it displays that it loaded the Black Jaguar program (and says it was built from SVN revison 60). In order to do anything else I have to change the configuration in Safe Mode. Once I take off the black jaguar option the cRio works fine.
I know all of my jaguars are updated and working since they all work in BDC-COMM.
Unread 20-01-2011, 18:56
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: [C++] CAN cRio image problem
Can you verify that you have the cRIO Image v25 installed?
Unread 21-01-2011, 09:57
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
I've seen this symptom when using the Black Jaguar plugin and I forgot to disable the console out dip switch on the cRIO. Could this be the problem?
Unread 21-01-2011, 10:50
Originally Posted by wt200999 View Post
...our cRio freezes right after it displays that it loaded the Black Jaguar program...
Where does it display this?
Good point. The console output goes to the same port as the messages intended for the Black Jaguar serial-to-CAN conversion.
Unread 21-01-2011, 15:28
Were you guys able to verify that this was happening to you?
