Go to Post Now stop reading CD, do your homework, eat your peas, brush your teeth, and go to bed. Any time you spend speculating as to what Dave's ravings might mean is completely wasted. - Richard Wallace [more]
Unread 19-01-2011, 14:52
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
JVN Build Tip: CIM Pinions
The CIM motor has 0.75" diameter protrusion on its face which is GREAT for piloting (keeping the CIM centered where you want). Relying on the (2x) 10-32 mounting screws will work, but won't result in as consistent a mounting. If you have any slop in your mounting holes the CIM could shift, resulting in a loose or tight gear mesh.
Typically, people use a 12-tooth or 14-tooth 20DP gear as a CIM pinion (see KOP transmissions).
One of my favorite tricks? Always opt for the 12t pinion. The 12t gear fits through a 0.75" hole while the 14t gear does not. This allows you to swap a CIM motor in/out without removing the pinion gear. You can have CIM motors on-hand ready to swap in.
Then again... I've never had to remove a CIM motor except to work on something else... Maybe this isn't such an expert tip after-all.
As always... good luck in 2011!
-John
Originally posted here: http://jvengineering.blogspot.com/20...m-pinions.html
