Go to Post I've learned never to say never when it comes to FIRST teams. - Karthik [more]
Unread 16-01-2011, 13:21
Yahya Gilany Yahya Gilany is offline
still learning !!
FRC #2445
Yahya Gilany is an unknown quantity at this point
Send a message via MSN to Yahya Gilany Send a message via Yahoo to Yahya Gilany
Question Mecanum wheels programming
Does any one have a working example on how to program a mecanum wheels to move side by side using LabView, please ??
Thanks!!
Unread 16-01-2011, 13:32
Re: Mecanum wheels programming
Thanks!!
There's a vi for that.
Holonomic vi
The "Y" input to the vi is for forward/reverse motion.
The "X" input to the vi is for strafe right/left (sideways) motion.
The "Rotation" input to the vi is for turning (yaw).
To take advantage of all three possible motions, you will need to provide those 3 inputs to the vi, so you will need a 3-axis joystick or two 2-axis joysticks or some other scheme.
Unread 16-01-2011, 13:44
still learning !!
FRC #2445
thanks a lot . does that works with 4 wheels that all in the same direction !! ( forward\ reverse) ??
I thought we might need 2 wheels going ( forward ) and the other 2 ( reverse ) so that it moves side by side !
Unread 16-01-2011, 13:52
thanks a lot . does that works with 4 wheels that all in the same direction !! ( forward\ reverse) ??I thought we might need 2 wheels going ( forward ) and the other 2 ( reverse ) so that it moves side by side
I'm not sure what you mean by the above, but there IS a right way and a wrong way to mount the mecanum wheels.
Take a look at this thread. The "X" and "O" mentioned in the post is the visual appearance of the mecanum rollers. The wheels themselves should all be aligned parallel to the robot's fore/aft axis.
Unread 19-01-2011, 15:31
Belenus Belenus is offline
Programing Team Leader
AKA: Jeoffrey
FRC #3140
Belenus is an unknown quantity at this point
Ok I am very new, and this may be a stupid question but where is the "Holonomic vi" I can not find it and non of the team is really great with LabView yet.
Thanks Jeff
Unread 19-01-2011, 16:06
Originally Posted by Belenus View Post
...where is the "Holonomic vi"...
At the bottom of the functions palette is the "WPI Robotics Library".
The first thing in the WPI Robotics Library is "RobotDrive".
You'll find the Holonomic Drive vi right next to Tank Drive and Arcade Drive.
Last edited by Alan Anderson : 19-01-2011 at 22:29. Reason: functions palette is not tools palette
Unread 19-01-2011, 17:34
BenGrapevine's Avatar
BenGrapevine BenGrapevine is offline
Head Programmer
AKA: Tony Simmering
FRC #2549 (Millerbots)
BenGrapevine is an unknown quantity at this point
Originally Posted by Alan Anderson View Post
At the bottom of the tool palette is the "WPI Robotics Library".
My team has decided on Mecanum wheels, and I still can't find the "WPI Robotics Library".
This is what I did, correct me if I'm wrong, PLEASE!
1. Open LABVIEW 2011
2. Go up to the "tools" bar
3. ?? (Where do I find the "WPI Robotics Library"?)
4. Holonomic Drive VI
5. Profits
Millerbots Team 2549
orange and blue
Unread 19-01-2011, 18:05
AKA: Jeoffrey
FRC #3140
Thanks everyone, you all are very helpful.
Unread 19-01-2011, 22:28
I meant "functions palette", not "tool palette". Sorry about that.
You can open the function palette by right-clicking on a blank spot in the block diagram, or by choosing "Functions Palette" from the View menu.
Unread 20-01-2011, 17:01
Head Programmer
AKA: Tony Simmering
Forget my comment, I learned how to make mecanum from scratch.
orange and blue
