Go to Post Honestly, I can't understand why anyone wouldn't want to be a mentor. The fools don't know what they are missing. - Steven Smith [more]
Unread 19-01-2011, 15:28
cheezburger's Avatar
cheezburger cheezburger is offline
FRC #0686 (Bovine Intervention)
cheezburger is an unknown quantity at this point
Holonomic Drive Program
My team is switching to Java this year and we want a holonomic drive system.
Not quite sure how to program it. When we tried to use the holonomicDrive method, Netbeans gave us a slew of errors, the most common of which was that
"holonomicDrive(float, float, float) is not public in edu.wpi.first.wpilibj.RobotDrive; cannot be accesed from outside package."
This is the code we have:
public void operatorControl() {
while (true && isOperatorControl() && isEnabled()) // loop until change
drive.holonomicDrive(leftStick.getDirectionDegrees (), leftStick.getMagnitude(), rightStick.getX(GenericHID.Hand.kRight));
Timer.delay(0.005);
I'm open to help in fixing holonomicDrive or to help in making a holonomic from scratch, as long as it works. The place I got the current code from said it was not tested code. I'd like code that has been known to work.
i can has cheezburger?
Unread 19-01-2011, 15:38
Jared Russell's Avatar
Taking a year (mostly) off
Re: Holonomic Drive Program
I don't see RobotDrive.holonomicDrive in the 2011 JavaDoc. You could use one of the mecanumDrive methods, however - the code for open-loop control of a holonomic drive with 4 wheels on 45 degree angles is identical to the code you'd use for a mecanum setup.
Unread 19-01-2011, 15:44
Could you give me a link to that?
Unread 19-01-2011, 16:13
http://www.wbrobotics.com/javadoc/in...w-summary.html
Look in edu.wpi.first.wpilibj.RobotDrive for the "mecanumDrive_XXX" methods.
Unread 19-01-2011, 16:44
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Its actually
drive.MecanumDrive_Polar(leftStick.getDirectionDeg rees (), leftStick.getMagnitude(), joystick.getTwist());
Unread 14-02-2011, 07:24
thanks for all the advice, we ended up making our own drive without the provided methods
everything is working now.
Unread 14-02-2011, 08:49
I'd be curious to see what you came up with. Are you open to sharing it?
