Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Unread 19-01-2011, 17:14
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Pressing Pinion onto Banebot RS775
Originally Posted by sanddrag View Post
Anyone have an opinion of plopping an AM planetary into a 3-stage GEM-500 and driving it with the 775 with a drilled out and pressed on FP pinion? And then maybe go 3 or 4:1 in sprockets and chains to an arm with say 75 ft-lbs of torque at the arm joint. Doing the same with a P60 worries me a little.
I reckon it'd work mighty-fine, and be a good deal stronger than a P60, due to the all-steel 20DP gears. Anyone agree? I take it's rather easy to modify the AM planetary motor plate to accept the 775?
My intuition says that it'll work fine. 75lb-ft at the arm joint? o.O remember that the RS775 (or any motor) won't put out "stall torque" for any appreciable amount of time, it's breaker will trip.
