Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
  #46   Spotlight this post!
Unread 19-01-2011, 18:24
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
Re: where is the iiko model ?
Originally Posted by Jreed129 View Post
Make sure that if you edited anything on him you didn't mess up the id mapping numbers, the head and eye lids should be matid 2 and body, arms, and legs should be matid 1 also make sure you apply the right map to the right id number in mat editor U1_v1 is the body and U2_v1 is the head
I just remade it and made it in several different colors for a bit of diversity. We have one scene where there are 12 iikos so gotta add some change.
The only thing about your fix is i can't figure out how to apply it to just his head. His body and head are one piece.
Former Driver and Safety Captain of team C.O.R.E. 2062 (Community of Robotic Engineers)
2015: Wisconsin Regional- Champions, Industrial Safety Award
Midwest Regional - Champions, Industrial Safety Award, Industrial Controls Award
2014: Midwest Regional - Judges Award
2013: Lake Superior Regional - Champions
2012: World Championship - Industrial Safety Award, World Finalist for the Autodesk Award
2011: Wisconsin Regional - Website Award 10,000 Lakes Regional - Innovation in Control, Safety Award
2010: World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
10,000 Lakes Regional - Regional Champs, Entrepreneurship Award
Wisconsin Regional - Entrepreneurship Award, Industrial Safety Award
2009: WI Regional- Quality Award, Industrial Safety Award
10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008: World Championship - Industrial Safety Award,
Wisconsin Regional - Champions, Industrial Safety Award
  #47   Spotlight this post!
Unread 19-01-2011, 18:33
Jreed129's Avatar
Jreed129 Jreed129 is offline
animation mentor
AKA: Jeremy Reed
FRC #0103 (Cybersonics)
Jreed129 will become famous soon enough
You need to go back to when he is an editable poly and then select the faces of the head and make them id 2 and like wise the faces of the body/arms/legs and make them id 1 sorry if i wasn't clear before
when the question about skin comes up yes/hold is the correct answer
  #48   Spotlight this post!
Unread 20-01-2011, 14:02
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Originally Posted by CaptainChris View Post
ok so i have the iiko rigged to a biped but now the eyes and teeth no longer move with the skin, also the mouth and ears no longer can move, any suggestions on how to fix this problem i have?
The iiko is already rigged - you probably lost its functions when you attached it to a biped.
  #49   Spotlight this post!
Unread 20-01-2011, 14:27
FRC #0847
We would like to scale an iiko to be children and adults... when we try to do that, (after unfreezing) it does not scale uniformly. IOW, the hips, neck, head etc scale on x and y, but not z. Seems like the iiko mesh scales everywehre except its anchored at the rig control points.
Any advice?
  #50   Spotlight this post!
Unread 20-01-2011, 16:05
AKA: Daniel C.
Any advice?
I have the same problem.
  #51   Spotlight this post!
Unread 20-01-2011, 18:01
MrPowers399's Avatar
MrPowers399 MrPowers399 is offline
Team Leader of Dinosaurs
AKA: Austin Reynolds
FRC #0399 (Eagle Robotics)
Team Role: Animator
MrPowers399 can only hope to improve
Send a message via AIM to MrPowers399
Hmm :/
We are using multiple computers. One is using 3DS Max 2011 64-bit and all of the others are using 3DS Max Design 2010 32-bit.
Is there any way we can easily convert these files to be compatible with each other because every time we save one in 2011, it does not open properly in Design 2010?
  #52   Spotlight this post!
Unread 21-01-2011, 19:13
CaptainChris CaptainChris is offline
FRC #1730
CaptainChris is an unknown quantity at this point
can I ask why you would want to get rid of the arrow?
i'm not 100% sure but break(broken chain in upper left of viewport) the space wrap that is connecting the skin and the arrow and you should be able to delete it[/quote]
the arrow is there durin the render is why i would want to get rid of it
  #53   Spotlight this post!
Unread 21-01-2011, 19:19
Jreed129's Avatar
animation mentor
AKA: Jeremy Reed
If you right click on the object and go to object properties you should be able to turn off the renderablilty of the object at hand....
  #54   Spotlight this post!
Unread 21-01-2011, 19:35
Aussie Oi!'s Avatar
Aussie Oi! Aussie Oi! is offline
FRC #3132
Aussie Oi! is an unknown quantity at this point
Question Re: where is the iiko model ?
cannot we make our own iiko modle?
  #55   Spotlight this post!
Unread 21-01-2011, 19:41
FRC #1730
Thanks Jeremy, i figured i would try one more thin before i affected render-ability and i Right clicked on the arrow and hit hide and for some reason it worked!!! its a miracle!!
  #56   Spotlight this post!
Unread 21-01-2011, 19:47
Nerd_Skywalker's Avatar
Nerd_Skywalker Nerd_Skywalker is offline
Walker of Skies
FRC #1111
Team Role: Animator
Nerd_Skywalker is an unknown quantity at this point
Does anyone know how to move the entire model? You can't keyframe the arrow thingy...
This is pretty obnoxious, I'm sure it was like this last year though
Re-dun-dant adj. 1. See redundant
  #57   Spotlight this post!
Unread 21-01-2011, 19:49
Aussie Oi!'s Avatar
FRC #3132
Do we have to follow this disine or can we make our own iiko
  #58   Spotlight this post!
Unread 21-01-2011, 19:53
FRC #1730
JREED, is there any way to get the mouth to move after i have rigged the skin to a biped?
  #59   Spotlight this post!
Unread 21-01-2011, 19:54
Walker of Skies
FRC #1111
Team Role: Animator
I'm sure you can have some creative freedom with them.
  #60   Spotlight this post!
Unread 21-01-2011, 20:01
Team Role: Animator
In the prompt it says we may use their Iiko, make our own, or not even use an Iiko at all.
