Go to Post I wake up at noon on Christmas Eve, and find tweets announcing a game hint. Looks like I won't be seeing much of my family today... - Karibou [more]
Unread 19-01-2011, 18:12
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
pneumatic usage question
Were planning on having an arm and tube gripper powered by pneumatics. The arm design depends on the claw/grabber we make, so were were waiting on exact measurements on it until the claw is done. The arm design uses 2 pneumatic cylinders, but if it needs to extend longer then it may use 4. We are torn between two designs for a gripper/claw, both of which use one pneumatic cylinder.
My question is:
If we were to lock onto a tube with our claw, whatever design it is (Both of our choices have one pnuematic cylinder) and then go to lift the arm and then extend it, will the system have enough air to keep a good grip on the tube? How far would the pressure drop if we used two on the arm? four?
Unread 19-01-2011, 18:22
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: pneumatic usage question
To answer this question we will need to know the size of each cylinder (length and diameter) and the size and number of storage tanks you plan to use.
Unread 19-01-2011, 18:25
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
I would suggest trying to find the specs, test strain, etc. The power of your compressor (which must be A, the one they gave you, B, one of equal strength, or C of lesser strength) may be able to cope if you get a large enough tank or set of tanks.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 19-01-2011, 18:26
AKA: Brandon Liatys
none if it is exactly planned out. Some one brought up the problem so I figured I'd post it. We have the storage tank from the kit this year and 4 smaller ones, plus whatever we got last year (we didn't use pneumatics last year). Is it the more the better?
Unread 19-01-2011, 18:29
Zuelu562's Avatar
AKA: Jake Janssens
The amount of air storage increases, and therefore, as long as you stay within the safety limits regarding psi, more is most certainly better. Be careful about the weight though.
Team Resume
Volunteer Resume:
Unread 19-01-2011, 18:50
IndySam's Avatar
Find the volume of your storage (small storage tanks from the past were 18.85)
Multiply by the amount of air pressure. 18.85 x 120 psi = 2262 working units. Find the volume of your cylinder (2"dia with 4" stroke = 12.56)
Multiply by working pressure of 60psi = 753 units
So one extension and retraction would use 1506 of you 2262 working units.
You can see from this simple example figuring pneumatics isn't too difficult.
Make yourself a spread sheet and go to work. You should also figure out how fast your compressor of choice can replace your working units.
Unread 19-01-2011, 19:01
RMiller RMiller is offline
Taking a Year Off
AKA: Ryan Miller
RMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really nice
Two notes: In this case, without the compressor, you will not actually reach 60 psi in the cylinder on the retraction. Instead, it will be about 48 psi - across the entire system).
Note, that the working pressure IndySam is the maximum allowed. If a lower pressure can be used, you will get more extensions and retractions of you pneumatic for the same amount of air.
Like IndySam said, make a spreadsheet and see what your numbers are.
2002-2004: 967 Mean Machine
2006-2008: 1816 Green Machine
2008-2010: 2739 Bucket of Bolts (BOB)
Unread 19-01-2011, 19:08
IndySam's Avatar
Absolutely correct, just remember to know the minimum psi that your valve will work with, you can only drop the pressure so far.
You can even do different pressures for the open and retract if you use multiple regulators and solenoids.
Unread 19-01-2011, 20:22
blhenze blhenze is offline
Bernie H
FRC #2333 (Sapulpa Chieftain Robotics)
blhenze is an unknown quantity at this point
We are looking to use pneumatics for the first time this year. We want to use it to extend and retract an arm with a gripping device. I don't anticipate the arm weighing a lot as the rings it will lift are very light. Does anyone know if the 3/4" bore and the 12" stroke Bimba cylinders will do the trick (or do we need to go to a bigger bore?
Unread 19-01-2011, 20:29
AKA: Brandon Liatys
Im not an expert but from experience, any bore would have the same power, its just a matter of how far. no matter if its 12" or 6" its still 60psi
But I could be wrong, thus why I made this topic lol.
Unread 19-01-2011, 21:47
IndySam's Avatar
3/4" bore will give you about 26lbs of force.
Unread 19-01-2011, 21:52
IndySam's Avatar
Yup you're wrong
the 60psi is pushing against the piston so the more surface area you have the more force you have.
A 2" cylinder will have seven times more surface area than a 3/4 cylinder, seven times more force.
Unread 24-01-2011, 12:31
Nick LaPosta Nick LaPosta is offline
FRC #2495 (Hornets)
Nick LaPosta is an unknown quantity at this point
Send a message via AIM to Nick LaPosta
How do you calculate the working units an actuator needs to move?
TEAM 1647 - Mentor
TEAM 2495 - Mentor
Unread 24-01-2011, 20:12
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Bimba is a great company, particularly for their support of FIRST. However, Clippard has a fun and useful online calculator for bore diameters. The strokes depend upon the geometry of your mechanism. the working units mentioned previously can be calculated from all that design done first.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
