Go to Post The more interesting arguments were around a related subject: whether it was pronounced "Wago tool" or "screwdriver". - Billfred [more]
Unread 19-01-2011, 20:00
Thee Alchemyst Thee Alchemyst is offline
Columnist/Novelist/Elo Technician
FRC #3461 (Operation PEACCE)
Team Role: Electrical
Thee Alchemyst is on a distinguished road
Rookies Seek Electrical Wiring Help!
So I've figured out what parts need to go where when it comes to the IO Module, the analog breakout, and the solenoid. I've found the printouts of the pinouts. But along the male pins, do you wire the pin to each pin via breadboard, or do I solder a bunch of wires???
Unread 19-01-2011, 20:10
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
Re: Rookies Seek Electrical Wiring Help!
Be specific. What device(s) do you wish to connect?
Unread 19-01-2011, 20:13
I have an IO Module Pinout that states that the (for example) the J2 column pin P0_0 is connected to an Analog Input 0.
I'm assuming the Analog Input 0 is located on the Analog Breakout, right? If so, they are both male pins on either component. How are they connected?
Unread 19-01-2011, 20:15
FRC #2190
For starters:
Control cables:
http://www.usfirst.org/uploadedFiles...%20%281%29.pdf
Power cables:
Unread 19-01-2011, 20:19
FRC #2190
Have you looked at the pdf titled, "How to Set Up Your Robot Control System 2011 FRC - LogoMotion"?
Unread 19-01-2011, 20:25
FRC #2190
Scratch that ... not a lot of help.
Are you trying to connect the cypress first touch i/o module?
Unread 19-01-2011, 20:27
FRC #2190
Can you provide a link to the documentation you're looking at?
Unread 19-01-2011, 20:29
I've been told I'm looking at the QuickBuild files. If that helps you at all. Scroll down to FRC Game Manual Section 4
Unread 19-01-2011, 20:34
I'm using the QuickBuild packet off the USFirst website. It's under the FRC Game Manual, section 4.
Unread 19-01-2011, 22:01
FRC #2190
I think you're referring to the Cypress module. Search the chief delphi forums for "Cypress Tutorial". I'm pretty sure that unit is supposed to connect up to the driver station NOT the cRIO.
Unread 19-01-2011, 22:35
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
I see you're in Terryville! Send me a PM. I'm in Bethlehem, probably 10-15 minutes away, and I work with Team Beta, Nonnewaug High School's team (in Woodbury). I'm sure we can help you guys out locally.
Unread 19-01-2011, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
What he ^^ said is probably best.
In any case, please avoid soldering anything directly to any pins on the cypress module for now. It's nearly impossible to un-do that, and it'd not be good to have to buy another.
They do sell connectors for those pins, they're called "0.100 header" connectors. Look at digikey.com for some examples of male & female connectors (the males are soldered to the PC Board, females go to wires, like the PWM cables in the KoP)
