Go to Post It's a bit sad, really, because FIRST has already reached other countries and there are some U.S. states that still are unaware of what FIRST is!! - tribotec_ca88 [more]
Unread 19-01-2011, 11:10
mint564 mint564 is offline
FRC #0564 (Digital Impact)
mint564 is an unknown quantity at this point
downloading code on to robot difficulty
my team is having difficulty with downloading code once we edit it. we can download the default code just fine, but once we edit it we start having issues. we used java last year with no real problems like this.
when we compile our code there are no problems, but when we download our code it gives us an error saying that one of the jaguars we declared in our code is already being used, even though it isnt being used in anyway that i can see. we tried removing it then which made the code the same as the default, but we continue to have the same problem.
Does anyone know why its doing this?
Unread 19-01-2011, 22:24
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: downloading code on to robot difficulty
Wanna share the error?
Unread 20-01-2011, 13:13
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
you mean like imaging the Crio with the code right? or do you mean like what netbeans does. Are you running the code from netbeans or like what you would do in the competition with the drivers station stuff?
Unread 20-01-2011, 15:11
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Are you just adding a Jaguar without any other modifications? Is there a stack trace/exception being given?
The default code may have defined some things as examples, though I doubt it. What is the exact error and how is it shown? In the console output, error dialog?
And what/where are you coding? Java w/ FRC Plug-ins in NetBeans or Eclipse? Also, have you updated to the latest version of whichever plug-ins you are using? (the SDK was updated in the last few days)
CRUD Name: Windows
Alumni to Team: 350
Unread 22-01-2011, 09:22
we're using netbeans, and w'ere declaring Jaguars the same way we did last year:
Jaguar one = new Jaguar(4,1);
um well this is what the error comes up as:
Uncaught exception in Thread.run():
[cRIO] on thread edu.wpi.first.wpilibj.defaultCode.DefaultRobot - main
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: PWM channel 1 on module 4 is already allocated
[cRIO] at edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:112)
[cRIO] at edu.wpi.first.wpilibj.PWM.<init>(PWM.java:141)
[cRIO] at edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java: 33)
[cRIO] at edu.wpi.first.wpilibj.Jaguar.<init>(Jaguar.java:41 )
[cRIO] at edu.wpi.first.wpilibj.RobotDrive.<init>(RobotDrive .java:84)
[cRIO] at edu.wpi.first.wpilibj.defaultCode.DefaultRobot.<in it>(DefaultRobot.java:125)
[cRIO] in virtual method #11 of com.sun.squawk.Klass(bci=53)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(99)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
Unread 23-01-2011, 13:13
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Can we please see your code?
Unread 23-01-2011, 14:00
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Do you have anything else using PWM channel 1? Victors, Jaguars? even if it's declared as:
new Jaguar(1)
instead of:
new Jaguar(4,1)
Slot 4 is the default Digital IO slot in the cRio.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 08-02-2011, 23:06
LiquidMagik LiquidMagik is offline
FRC #0649
LiquidMagik is an unknown quantity at this point
we are having the same exact error except with a DigitalInput. the error line is instead:
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: Digital channel 1 on module is already allocated
i dont think anyone replied with advice to the team and it has been a week or two so i assume the problem has been fixed. help? only 14 days left!
Unread 08-02-2011, 23:07
FRC #0649
module 4*
Unread 09-02-2011, 11:17
Ben_R_R's Avatar
Ben_R_R Ben_R_R is offline
Assistant Programing Mentor
FRC #2194 (Fondy Fire)
Ben_R_R is an unknown quantity at this point
Solution to the original problem in case anyone else has this problem:
Check if you are declaring any new RobotDrive objects. If I recall the default code robot drive takes 4 PWM channels as arguments, but it will work if you are running the motors off the first 2 PWM channels. If you are only using 2 PWMs to run your motors, you can free up the extra channels like so:
Find this line:
m_robotDrive = new RobotDrive(1, 3, 2, 4);
Change to:
m_robotDrive = new RobotDrive(1, 2);
See if that helps.
@LiquidMagik
check along the same lines as above. Make sure none of the other objects are using the digital channel 1. If you can't find anything, see if the problem goes away when you change channels.
2194 Alumni and Mentor
Unread 09-02-2011, 23:00
FRC #0649
Thank you for the help but we use different classes since we are using omni drive. We have each individual motor object from the victor class. We'll talk with our programming brobo tomorrow.
THANKS team 649
Unread 09-02-2011, 23:40
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Our team is using omni/mecanum wheels this year as well. I was just thinking, we had this same error and all too with our servos, and I think it might have something to do with not defining slots on any of the others.
such as
// see driver station dashboard for module numbers
Gyro gyro = new Gyro(1); // Gyro in PWM channel 1
Servo servo = new Servo(4,1); // Servo in Digital IO channel 1
Do you think it might have to be
Gyro gyro = new Gyro(1,1);
for it to work correctly?
All just complete guessing, I'm kind of hopeless right now, it seems the robot just doesn't want to cooperate this month.
If anyone finds the real answer, please share!
Thanks.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
