Go to Post Nobody has ever complained that someone was too willing to share their knowledge of building robots or their new ideas for anything. - Josh Hambright [more]
Unread 19-01-2011, 21:55
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Pulley Radius: how to factor this into calculations?
Hi guys,
My team is thinking of using a winch for an elevator system. Naturally, we need a few pulleys. From what I learned in my physics courses, pulleys just redirect the direction of force/weight. However, we all know the AP curricula mostly assumes the "perfect physics world."
Theoretically, smaller pulleys have a lesser moment of inertia, but I am not sure if that even factors into our FIRST-scale applications. On the other hand, I have heard anecdotally that larger diameter pulleys are "better" (sorry, don't know the physics-related term I can give for this).
Please help enlighten some confusion on my team.
-Logan
Unread 19-01-2011, 22:45
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Pulley Radius: how to factor this into calculations?
Pulley inertia can be ignored. Really small ones have to rotate faster, and friction increases a little. Big ones rotate slower, reducing friction effects.
In general, for most pulleys, you pick the size based on purely mechanical considerations: Does it fit the mechanism well. For an elevator, something in the 1 to 4 inch range (depending on the size of the elevator structure members) would probably be about right.
Unlike gears and sprockets, the size of pulleys used for an elevator system (those that are not being driven by a motor at least) doesn't matter much.
Unread 19-01-2011, 22:57
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Would having a pulley with too small a diameter really matter in FRC-application type loads? I'm thinking of a scenario in which a high load on a tightly wrapped belt could cause it to suffer extreme fatigue and snap.
Attending: MN Duluth Regional
Unread 19-01-2011, 23:08
AKA: Logan
Thank you very much for the input!
We are thinking of wrapping 1/8in steel cable around pulleys that are 1/2in in diameter. They need to be as small as possible to fit inside of our elevator assembly.
Our fear is that there is not enough "wrap" around the pulley, and pulling the wire around such a small diameter will be almost akin to pulling the wire across a sharp corner. I am not sure if I described this well enough....
Unread 19-01-2011, 23:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
What type of steel cable is it, and what is its minimum bend radius? The minimum bend radius will likely be your minimum pulley size.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2011, 23:54
AKA: Logan
I don't know much about the cable other than the fact that it is 1/8inch in diameter and was taken from one of our mentors' planes.
Unread 20-01-2011, 00:19
artdutra04's Avatar
How many strands does it have? The more strands it has, the more flexible it'll be.
Art Dutra IV
世上无难事,只怕有心人.
Unread 20-01-2011, 08:05
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Pulley Radius: how to factor this into calculations?
Minimum bend radius is very important - the more strands, generally the smaller the acceptable radius. Have you investigated Spectra cord? Very flexible, light weight, and stronger than steel cable for a similar cross section. Teams have been using it for years.
Here's an EBay item number to 1/8" cord at a very good price---180614836330
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 20-01-2011, 08:08
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
If you must have that small of a pully, you might want to look into Spectra or other performance kite strings. You can get a roll of 450 feet for about $100. Really great stuff.
