Go to Post Here's some food for thought: Does your FRC program need the students, or do the students need your FRC program? - sanddrag [more]
Unread 16-01-2011, 15:34
adf0221 adf0221 is offline
FRC #1517 (Lumberjacks)
adf0221 is an unknown quantity at this point
DLink 1522
Our DLink 1522 freezes when we try to change network settings in bridge mode. We have tried different computers, reset the DLink, etc. We can set up the AP mode but will it work the same without the bridge mode? Anyone have any opinions, had the same problem, or know how to properly change the settings in bridge mode?
Also should we change the NetBios name or leave it in its default?
Unread 16-01-2011, 19:06
Re: DLink 1522
Leave the NetBios name alone.
I assume you followed the FRC directions, at what step and where did it freeze?
Did you try different web browsers in addition to your different computers?
Unread 16-01-2011, 21:19
rsisk's Avatar
rsisk rsisk is online now
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: DLink 1522
If you are referring to the fact that the final save of settings right before progressing to the AP setup never finishes, that is to be expected.
The IP address is set to a 10. sub net, the computer is still on a 192. subnet, so it never sees a response from the DLINK that the save is complete.
Just move on to the next step of configuring the AP portion.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 18-01-2011, 13:50
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
Re: DLink 1522
I have completed the setup without any problems, but I do have a problem connecting to the D-Link wirelessly. The router must be in bridge mode to connect to a netbook right? when in bridge mode the netbook does not see the router. If I change the router to AP mode the netbook finds the router. I have tried to connect to the router while in AP mode, my netbook ip is 10.15.29.5 (that's what it's supposed to be right?). the netbook sees the security on it, I enter the WPA key, then it thinks for a while and eventually does not connect and will never find that wireless connection again until i reset the router to factory defaults and go through all the steps.
~Team 1529 Cybercards~
Unread 18-01-2011, 13:53
Re: DLink 1522
The D-Link must be in AP mode to connect to the Classmate.
10.15.29.5 is correct for your Classmate/Driver Station.
Try it with security turned off.
Unread 18-01-2011, 14:07
FRC #1529
Re: DLink 1522
After a quick restart the netbook magically connected with the D-Link. Thanks for your quick response.
really? #2 under 'Configuring the Radio for Competitions', it says, "The radio must be in Bridge mode at competitions."
Unread 18-01-2011, 14:12
Re: DLink 1522
At competitions the Driver Station is connected by Ethernet cable directly to the Field Router.
The Field Router connects wirelessly to the bridge on the robot.
A bridge and a laptop wireless card are sort of like clients that need a router somewhere to connect to.
When the D-Link switch is set to AP, it acts like a router and the Classmate can connect to it, but when the D-Link switch is set to Bridge, it acts only as a bridge, not a router, and only another router can connect to it.
There is an exception for some bridges that support ad hoc networks, but that doesn't apply to our equipment.
Unread 18-01-2011, 14:16
FRC #1529
Re: DLink 1522
Oh, that makes sense! Thanks!
Unread 19-01-2011, 12:19
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
Re: DLink 1522
we're having problems at an earlier stage:
6. Click on the Setup tab on the top menu bar
7. Click on the Wireless tab on the left side of the page
8. Change the Wireless settings as follows:
My WIRELESS tab is completely empty. I can see where all those boxes with settings should be, and they're not there. we're the only ones with this problem?
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 19-01-2011, 12:24
Re: DLink 1522
Try using IE as a browser. People have discovered that some web browsers, like Firefox, don't play well with the D-Link.
You are not alone...
Unread 19-01-2011, 12:42
Daniel_H's Avatar
Re: DLink 1522
It worked!
Thanks!
[<o>] gogogo [<o>]
Unread 19-01-2011, 19:08
Daniel_H's Avatar
Re: DLink 1522
once I have Dlink 1522 correctly configured, what's the next step to have everything communicanting wirelessly?
I couldn't find anywhere if previous years' linksys router for the driver station will continue being used, nor its configuration steps.
I see a gap in the manuals concerning this part
[<o>] gogogo [<o>]
Unread 19-01-2011, 23:03
Re: DLink 1522
Setup the classmate to use it's wireless connection (set the IP) and disable the Ethernet Local LAN.
You should be able to get it to connect directly to the D-Link network (SSID= your team number).
Unread 19-01-2011, 23:26
Re: DLink 1522
The manuals indeed say nothing regarding last year's router. That's because last year's router is not used this year.
The "next step" should already have been done. If you set up the Classmate properly, it will connect wirelessly to the DAP-1522 using your team number as the SSID.
Unread 21-01-2011, 22:31
Daniel_H's Avatar
Re: DLink 1522
so, I just need to configure the radio as says on the manual and have my passphrase "1156WPAKEY"?
I can imagine it working while on driver station mode, but how about during the developing code period where we don't use the driver station software?
btw, I wish I could test this stuff by myself and save you the time of answering these elementary questions, but today we managed to burn our kOP's router (220V outlets and my careless apprentice..) and we're having a hard time finding an identical one here in Brazil. If we are to get a new radio only when we are at our regional in NY, I'd like to know as much as I can beforehand to avoid surprises.
Thanks.
[<o>] gogogo [<o>]
