Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 19-01-2011, 00:48
Aren Siekmeier's Avatar
on walkabout
Team 2175 Logo Motion Robot Design
This is the product of our first week of brainstorming, prototyping, and design.
Our strategy:
-Score pieces quickly. Quick ground to peg time.
-Be maneuverable. This speeds up piece retrieval and helps us place them accurately (particular by strafing).
-Make it simple and reliable. We hope to attend 2 or 3 events this year as opposed to previous years' 1, so we want it to last.
-We also hope to have more of it CADed before construction so it can come together more cleanly and much, much more quickly, leaving lots of time for code, testing, and practice.
Our solution:
We determined that strafing was very near a requirement for placing the pieces because tank turning would be very limiting and almost always slower even with practice. We therefore arrived at the holonomic drivetrain that we prototyped; the competition robot will use four 4" dualies. It favors the forward direction (2 CIMs per side) for faster field traversal, but still strafes (with 1 or 2 RS 775s per wheel) and turns very well over short distances. The frame is an octagon to increase stability (?) and keep turning effortless. It will be welded aluminum box tube, 1" by 1/8" wall.
For a lift mechanism we have decided on an elevator very similar to that of Team 25 from 2007. We got the idea from the 2007 Behind the Design book, and watching match videos confirmed that it worked well. We determined that we needed to pick up off of the ground, because we think most of the pieces will be there at some point, and we don't want to be limited to the slot. The elevator can reach the top peg with just 2 stages and a gripper that rotates the game piece from pickup position (horizontal) to scoring position (vertical). It will be powered by an FP and should be able to lift at 12 ft/s (!), not counting inefficiencies, friction, etc. The gripper is not yet finalized, but will likely be a simple pneumatic clamp.
All the electronics, battery, and motors will fit within the 12" tall octagon (not shown). The minibot will conveniently sit on top behind the elevator, at the appropriate deployment height. Design work to be done includes the gripper and the minibot and minor details for the elevator and the drivetrain.
We haven't decided on a name yet. Suggestions welcome!
Unread 19-01-2011, 00:56
Flyer522's Avatar
Flyer522 Flyer522 is offline
AKA: Holton
FRC #3753 (Raptor Robotics)
Flyer522 is an unknown quantity at this point
Re: Team 2175 Logo Motion Robot Design
Looks very cool! Great work! Does the CAD have 6 Jaguars on it?
Team 3753 | Raptor Robotics
2011 Bayou Regional Highest Rookie Seed Award
2011 Bayou Regional Quarter-Finalist (w/ 1912 & 3672)
2012 Bayou Regional Quarter-Finalist (w/ 1912 & 1927)
Data is not information.
Information is not knowledge.
Knowledge is not understanding.
Understanding is not wisdom.
Unread 19-01-2011, 01:18
DiscoKittyPrime DiscoKittyPrime is offline
AKA: Joshua Bryant
FRC #0057 (Leopards)
DiscoKittyPrime will become famous soon enough
This looks like a good design. I do have some questions for you that are born out of curiosity and not criticism.
1.) How do you plan on picking up the tubes from the floor easily with the telescoping lift centered in the bot?
2.) The placement of your batter seems a little difficult to reach from the views that you have provided. Have you guys planned on an easy way to change out your batteries?
Just curious about your design choices but it looks like a solid design non the less. Best of luck.
Unread 19-01-2011, 09:25
pfreivald's Avatar
AKA: Patrick Freivald
What gear reduction are you thinking for the FP?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 19-01-2011, 09:48
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
Wow I showed a fellow mentor your photos and he asked me when I drew up our design. We have the same exact design. Hopefully it works.. we may have to compare notes.. Good luck
Unread 19-01-2011, 09:52
dodar's Avatar
dodar dodar is online now
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
If anyone on your team likes watching the UFC, they could name your minibot Brock and just call your robot The Octagon.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 19-01-2011, 11:04
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
I like how you included the electrical components in your model (wish we had done that last year... )
I do, however, want to know how you plan on changing your battery. it looks pretty buried/stuck in the bottom.
looks nice!
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 19-01-2011, 11:55
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
That looks really similar to our design.
We are only using 4 CIMs on the drive and are wheels are at 45 degree angles to the direction of normal travel(Picture). Omni drives like this actually travel faster in that orientation in the orthogonal directions (They travel faster then each individual wheel velocity) Source
Our lift is using spectra cord instead of timing belt but overall an extremely similar robot design. I hope we both do well in competition.
Unread 19-01-2011, 12:02
Chris is me's Avatar
AKA: Pinecone
They travel faster in that they can be geared higher than two motors would normally push in that direction; however drives like these allow the user to configure a particular direction to drive with more than the equivalent of two motors of "power", allowing a higher free speed / lower gear ratio in the primary direction of travel.
In short, "yes" but "no".
Unread 19-01-2011, 12:28
Engineering Coach
I am not sure I understand the first sentence here. A robot with four omni wheels placed 90 degrees apart will travel approximately 1.4 (or square root of 2) times faster than wheel velocity in it's orthogonal directions. At directions parallel to any wheel rotation the robot will only be able to travel at wheel velocity like any two wheeled robot. This is not saying it is geared any different. The robot is actually moving faster than any one wheel is spinning.
Your second statement is correct that by adding motors you are able to get a higher power, this is always the case. However this also makes doing the calculations for holonomic control of the robot very challenging since different wheels are able to travel at different velocities and will have different accelerations.
So to sum up yes their drive train will have more power and acceleration when traveling forward and backward than one that uses 1 CIM on each wheel (assuming consistent gearing). The drive with 1 CIM on each wheel will have a greater top speed when strafing and consistent control to all 4 wheels. These are just two different design and both have there ups and downs. And as always you can gear any drive train to have more speed when you sacrifice torque.
Unread 19-01-2011, 12:36
AKA: Pinecone
I meant that the net speed, all things considered, is potentially greater for a robot with four motors pointing in the intended direction of motion than a holonomic system, if the gearing is adjusted to compensate for motor differences.
Sorry about any confusion.
Unread 19-01-2011, 23:16
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
How does this pulley system function? It doesn't appear to be anchored to any of the lift components and therefore would essentially free spin like a belt in a loop. Just curious I actually love the design and have seen some ways we could fix some of the problems we have been having in our own design. Thanks for posting. The video of the omni drive is also pretty awesome I hope I get time to sneak over to Mariucci arena to get a look at this thing first when it's done.
Unread 19-01-2011, 23:19
Dr Theta's Avatar
Lead Mentor
AKA: Derek Messer
Never mind, I believe I spotted the anchor point, very clean. I'm impressed.
Unread 20-01-2011, 00:17
on walkabout
Right now it only includes the jags for the drivetrain. There will be at least one more for the lift mechanism, and possibly more depending on minibot deployment, gripper design, etc.
1. The gripper will have two positions powered by a cylinder. Vertical for starting the match within the frame perimeter and for scoring. And horizontal for picking tubes up off the ground. In the latter orientation, it will have to reach forward and over the bumpers to the ground.
2. The battery can just be lifted a few inches, tipped, and dropped out the bottom. That's the idea anyway, we haven't checked that the clearance will actually allow that. If not, there will probably just be thumb screws or something on the brackets holding in. Either way, it will be accessed from the bottom.
A 20lb arm climbing 10 ft in 1s is about 270W, appropriate for an FP it seems. With a 1" radius pulleys, we're looking about 8.5:1 off the FP. We're also considering two RS 775s, but we're unsure of the transmission options for that.
And actually, with four equally powered wheels, the robot goes slower diagonally, just with more torque (the wheel speeds don't add up, but the torques do). However, we can go twice as fast in one direction by doubling the CIMs there. Since we don't care as much about strafing, we demote them to RS 775s.
Yes, the belt is fixed to the final (gripper) stage. Powering the belt pulls this up and down at the same time as the first stage (or perhaps in sequence...). We realized that a closed belt would simplify things a lot, but at first were failing to see how to make it work. But conveniently the length lost between the stages will always equal the height change of the final stage, so the belt stays the same length (assuming its vertical). We actually verified this in Solidworks down to a thousandth of an inch. Pretty sweet. Of course, who knows if the real mechanism will work that well. The double clamp on the gripper stage also allows us to quickly tension the belt as needed while keeping it all working smoothly.
@Dr Theta: We might also be attending Lake Superior, depending on funding, so perhaps we'll see each others' handiwork there?
Unread 20-01-2011, 12:46
Engineering Coach
I'm not sure how to explain this better than other people already have before me.
This gif file on this page shows the relationship between standard drives, omni drives, and Mecanum drives. Ether does a great job of explaining the math and if you have questions he is usually happy to answer them.
The source I sited above also shows how the other motors are able to induce velocity (not force) perpendicular to the direction of rotation of any one wheel.
In fact wheel torque is .707 (1 over root 2) that of any individual wheel when traveling at a 45 degree angle to any wheel.
