Go to Post The hardest resource to come by in FRC is the one you can't buy: a well-trained, experienced, well-intentioned, dedicated mentor. - PayneTrain [more]
Unread 19-01-2011, 23:34
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Line Follower Power Array
Originally Posted by aeasson View Post
Anyone else experiencing this problem?
Does anyone have a solution?
Hi. This is actually how it's meant to work.
If those values were in a constant array (on the Block Diagram), they would update as you expect.
BUT, since they are on the front panel, you need to explicitly tell labVIEW that you want to save your changed values. To do this, go to the front panel and make your changes. Then, to "lock in" those changes right click on the control and select: "Data Operations / Make current values default".
Now when you save your VI, the new setting will stick.
I guess this behavior is so you can "play" with the values without actually losing your defaults.
Phil Malone
http://www.GEARSinc.org
Unread 20-01-2011, 08:16
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Thanks for your help.
