Go to Post I can still remember how weird it was to look on the other side of our booth and see a kid in a suit tossing purple balls... - OneAngryDaisy [more]
Unread 19-01-2011, 19:02
TwoFacedGunmen TwoFacedGunmen is offline
None #3268
TwoFacedGunmen is an unknown quantity at this point
Legal Control System?
I've looked through the rules, and can't find anything that says I can't do this, but by no means does that mean I am misinterpreting something or simply not looking in the right spot.
The idea:
Our robot will be using a articulated arm. We intend to use potentiometers to get the angle of each joint, and use information from said sensors to build preset configurations to easily place the tubes at certain peg levels. But we would still have a manual system just in case.
My idea for a manual control system is to build a miniature arm. This arm would be a scale model of the one on the robot. The mini arm would be equipped with potentiometers just like the full scale arm. Thus, when the miniarm is moved by a driver, the full scale will move to match.
If legal, the mini arm will be placed on a scale robot as a reference point, so that we don't accidentally smash the real arm into ourselves or the floor.
Is a miniarm control system legal?
Unread 19-01-2011, 19:19
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Legal Control System?
you can pretty much do whatever you want with the driver control system. This has been done before, and appeared to work well. Can't recall the team-done many years ago.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 19-01-2011, 19:20
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
I would suggest Q&A on this, really this is a case of innovative ingenuity, and I really don't see a reason they would decline the use of this unless they had a real good reason. Make sure to say everything you can. It makes the ruling that much more likely to give you the answer on this.
Aside, nice job thinking outside the box.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 19-01-2011, 19:23
Jimmy K's Avatar
Jimmy K Jimmy K is offline
FRC #1002 (Circuit Runners)
Jimmy K is an unknown quantity at this point
If it follows all the rules for control systems, it would be legal. Nothing that you mentioned would make it illegal.
The practicality of that control system is another issue, but I'm not an expert in control systems, so do what your team thinks is best.
That kind of system has been attempted in the past by some teams. I think our team tried something like that for Rack n' Roll (2007) which didn't work so well, but another team supposedly did that effectively and won the <Corporate Sponsor Name> Control Award at Peachtree.
EDIT: The award was the Rockwell Automation Innovation in Control Award.
Unread 19-01-2011, 22:45
Patrick Seeney Patrick Seeney is offline
Patrick Seeney
FRC #0469 (Las Guerrillas)
Patrick Seeney is an unknown quantity at this point
I am not sure which team it was, but back in either 1999 or 2000 some team built a strap on arm that did basically this. One of the drivers strapped it to his arm and the arm on the bot moved as his arm did.
Unread 19-01-2011, 23:00
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
We basically did the same exact thing for our 2007 robot. It was a scale arm built out of polycarbonate with potentiometers at the 3 joints for manual control. This is probably the most intuitive way to control a multi-jointed arm, but we have decided to never make an arm like that again. The arm itself performed great, but it was way too complex for the drivers to control during the heat of the moment. If you have decided to go with a multi-joint arm, I wish you the best of luck, but you might want to evaluate its practicality.
Unread 19-01-2011, 23:46
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I would code the arm to not destroy the robot rather than hoping the driver doesn't move the arm wrong. Additionally, what if the mini-arm bends such that , although the position seems safe on the model, it isn't.
Unread 20-01-2011, 17:11
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Our team was actually going to try something like this if we had time, but more of an arm-mounted thingamabob. We were going to take apart a joystick (we had some extra ones) so we didn't have to mess with getting the data to the robot.
Like others said, there should be nothing wrong with this. The only restriction I saw that dealt with robot-control is that the driver station is the only valid means of interacting with the robot.
Unread 20-01-2011, 17:33
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...ontrol+910+arm this might help with ideas
Unread 20-01-2011, 18:27
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
The team I used to be on (308) did this in 2000. When I went to team 65 we did it in 2005. It works very well and is highly intuitive for the drivers. Good luck.
