Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
  #61   Spotlight this post!
Unread 20-01-2011, 00:07
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Re: How should we wire the photoswitchs?
does this mean the black cable doesnt get connected to the dsc?
  #62   Spotlight this post!
Unread 20-01-2011, 09:44
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
The Black and the White wire provide the same information, just with opposite logic. When one is on, the other is always off.
No point connecting both.
Note: The colors were NOT chosen to be compatible with FIRST robots, so don't assume that black is GND. It's NOT !!!
Phil Malone
http://www.GEARSinc.org
  #63   Spotlight this post!
Unread 21-01-2011, 08:18
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
The sensors have 22AWG wire, but they must be connected to a 20-amp circuit on the PDB. By the rules, this requires 18AWG wire. Is there an exemption somewhere I am missing?
If not, I will bring this to the Q&A later today.
  #64   Spotlight this post!
Unread 21-01-2011, 08:40
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
If you splice the sensor power leads or use a connection block, they will need to connect to 18 AWG before terminating in the PDB. That will satisfy the wiring rules.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #65   Spotlight this post!
Unread 21-01-2011, 10:26
There's no explicit exemption. Sensors and custom circuits are typically not given as much scrutiny by the inspectors as are motor and relay power circuits, so they usually pass inspection even though they don't strictly follow the wire gauge rules, but you're right to be concerned.
A couple of years ago we used a small-valued inline fuse on a power branch that was going to a single Banner sensor (very much like the photoswitches in the Kit this year). That practice is mentioned in the wiring rules for custom circuits.
  #66   Spotlight this post!
Unread 21-01-2011, 11:18
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
Originally Posted by andreboos View Post
I've wired the sensor with:
Blue: +12v from PDB
Brown: Ground on PDB
White: a DS signal pin
Black: another DS signal pin
When it receives power the orange and yellow lights alternate. Is there any documentation about the status lights? I read the document regarding Teach mode but I don't think that applies to our sensor (no push-button that I can find).
I think my code is correct but I'd like to see example code (Didn't they specifically mention that in the kickoff broadcast?). I can't find any bundled with WindRiver.
Did you ever fix the alternating orange and yellow alternating lights? We have two sensors working properly just one does this weird alternating thing
  #67   Spotlight this post!
Unread 21-01-2011, 11:30
Yes, he did.
  #68   Spotlight this post!
Unread 21-01-2011, 15:28
tommy0019's Avatar
tommy0019 tommy0019 is offline
FRC #2957
tommy0019 is an unknown quantity at this point
we are trying to get our line sensors to work. we have it wired as:
sensor blue- 0v
Sensor brown- +12v
Sensor white- white pwm to signal pin on digital i/o section of the DSC.
sensor black- nothing
we were trying to run the autonomous mode from a new robot code project and it only runs a pre-programmed drive and doesn't respond to the sensors. then we put a jumper on the 2 power pins for the digital i/o side and when we enabled the autonomous mode nothing happened at all.
a note: our sensors are showing green when not by anything and orange and red when over the reflective tape. i heard the red meant it was over it's threshhold. what threshhold is that and is it fixed with the sensitivity knob or not?
I am asking if anyone could give any advice so we can get our line sensors working correctly.
  #69   Spotlight this post!
Unread 21-01-2011, 15:35
Originally Posted by tommy0019 View Post
then we put a jumper on the 2 power pins for the digital i/o side...
The Digital I/O side doesn't have 2 power pins or use jumpers.
Could you be connecting them to the PWM side (all white connectors)?
  #70   Spotlight this post!
Unread 21-01-2011, 16:04
tommy0019's Avatar
FRC #2957
The side of the DSC that is labeled Digital i/o has 14 sets of 3 pins(sig, pwr, -) we have the sensors connected as so all with the white pwm cables.
right to digital i/o 3
center to digital i/o 2
left to digital i/o 1
There is a set of two pins right next to those 14 that are labeled pwr and (-). i am guessing that they supply power to the digital i/o pins. we put a volt meter on the pins and the supplied power when the jumper was connected.
  #71   Spotlight this post!
Unread 21-01-2011, 16:11
Those pins are only an extra ground/5v set for devices that just need power.
Do not use a jumper to short those.
The Digital I/O was shorted out by that...
  #72   Spotlight this post!
Unread 21-01-2011, 16:15
tommy0019's Avatar
FRC #2957
those are the correct place to put them, right(without the jumper)?
do you have any ideas as to why our robot isn't responding to the sensors?
  #73   Spotlight this post!
Unread 21-01-2011, 16:25
Originally Posted by Alan Anderson View Post
Yes, he did.
So what'd he do then? Our robot just turns randomly in a cricle when we start the program and I'm not sure if this is the problem.
  #74   Spotlight this post!
Unread 21-01-2011, 16:27
The digital signal inputs sound good, as well as, the rest of the wiring.
The jumper would have disabled all the digital inputs while it was in place, but they should start working again after it's taken off.
It also sounds like the sensors are working just fine too.
I'd look at the code next.
Which edition of the Framework are you using?
Since there are two that do different things it may just be that you have the one that just drives rather than the one that follows a line.
If you use the Run button on Robot Main.vi in LabVIEW (assuming LabVIEW) you can probe the values coming back from the sensors.
  #75   Spotlight this post!
Unread 21-01-2011, 16:34
tommy0019's Avatar
FRC #2957
We used the robot framework with game code.
