Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Unread 20-01-2011, 00:51
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
D link wireless bridge
I can't get our driver station to detect our new wireless bridge. The steps I took for setting it up was just to go to http://dlinkap (I don't remember but something like that) and then I launched the wireless setup stuff while it was connected to the laptop of course. I have the switch set to auto and the bridge is in port 1 if that matters. Other than that everything works fine when the robot is on a wired connection.
Unread 20-01-2011, 01:12
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
Re: D link wireless bridge
Do you know about this site: http://www.usfirst.org/roboticsprogr....aspx?id=18530? I ask because I don't remember anything like "httyp://dlinkap"
If you haven't, I think that some specific documents that might help you are
How to Configure your cRIO (makes sure you're computer's IP is right)
How to Set Up your Driver Station
and How to Configure your Radio
Unread 20-01-2011, 04:19
mswalker mswalker is offline
FRC #2583 (Westwood Robotics)
mswalker is on a distinguished road
The D-link needs to be in AP mode to talk to the classmate in the lab. Bridge mode is used for competitions. This thread is helpful in talking about some setup issues: http://www.chiefdelphi.com/forums/sh...ghlight=d-link
Unread 20-01-2011, 08:03
The directions are on the FIRST website that CodeMonkeyMatt pointed you to, not the D-Link website.
How To Configure Your Radio
Unread 20-01-2011, 10:29
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Just one note to add: When you plug into the radio, you can go one of two ways to get to the website - either the IP address method in the document, or http://dlinkap. They'll both get you to the same place - D Link added a small bit of complexity to enable that on their devices to make everyone's lives easier (most people understand a web address like http://dlinkap, while they can be confused by an IP address).
Unread 20-01-2011, 10:32
Ah, I didn't know that and misunderstood.
Thanks for the shortcut!
Is there a corresponding "dlinkbr"?
Unread 20-01-2011, 11:15
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
make sure your laptops wireless ip is 10.xx.yy.50
xx.yy= team number
example 10.30.38.50
Unread 20-01-2011, 13:29
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Do you have to set the ip address as fixed on the development laptop? Its not obtained via DHCP from the DLINK?
Do you have to set the classmate's wireless address too? Should it be set to 10.x.x.5 like last year?
Do you have to press the button on the dlink when trying to connect?
Thanks,
Brian
Brian K
Team 1225 Robotics Mentor
Unread 20-01-2011, 13:47
If you don't have DHCP service enabled on the DAP, you'll have to set a static IP address on your development computer. It would probably be best to enable DHCP, telling it to give out addresses starting at 10.x.y.10 or so.
The Driver Station app should take care of setting the address. Yes, 10.x.y.5 is correct.
Never press the button. If it's anything like the older WGA, it's all about "easy" wireless security. You'll most likely end up with security enabled and an unknown WPA password. One of the first things we did was put a shield over the button so it doesn't get hit by accident.
Unread 20-01-2011, 17:24
Chingbotics1 Chingbotics1 is offline
FRC #3560
Chingbotics1 is an unknown quantity at this point
Our team is having similar problems in that we're having trouble connecting to our D-Link router wirelessly, but the difference is that we cant even get into the router settings. We type in dlinkap as well as 192.168.0.50 and that hasn't been working either. We're not sure what we can really do at this point. We keep the settings on bridge generally, but it doesnt work under AP either. But when under AP and (very oddly) the router is connected to the internet, it is able to ping the cRIO, but not actually doing anything with it in the control station.
Unread 20-01-2011, 18:32
Ok we have everything working on our classmate computer now, but now I can't connect to it with a regular laptop. I need to so I can put the labview code on to the crio
Unread 20-01-2011, 22:47
If you can't get your programming computer to communicate with the other devices, perhaps its IP address is not set to match your network.
Unread 21-01-2011, 00:30
I followed the entire guide posted for frc and it seems as though my classmate is the only thing that can connect to it. I also tried putting the ethernet cord directly into port 1 and into the my laptop and the laptop won't detect the cRio now when it did before I put the dlink on there. I don't understand how those two even correlate.
Unread 21-01-2011, 08:33
If your laptop has multiple network cards (wireless, Ethernet) the wrong one could be setup. It could be trying to go out over the wireless when it should be using the Local LAN.
  • If you are wiring directly turn off every NIC except for "Local LAN..."
  • Change the Local LAN IP address/netmask to what they are supposed to be, or just make sure they are correct.
Unread 21-01-2011, 10:46
I disabled all of them except the lac and it detects the router, but when I hit run as start up in labview it just gives me the failed to connect to real time target error
