Go to Post I didn't say this! - Max Lobovsky [more]
Unread 20-01-2011, 07:10
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Re: cRIO Problem
Yeah I did those steps, minus the run and deploy code because LabVIEW could not connect to the cRIO. I still get the error.
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 20-01-2011, 22:08
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: cRIO Problem
I'm going to throw this out there because we ran into it tonight.
If you install the imaging tool on a computer that already had it from a previous year you end up with 2 copies of the imaging program. One in the LabView 8.5 folder and one in the LabView 8.6 folder. The shortcut on our desktop got changed but the one in the start menu did not and this stumped us for a while. Because we were running last years or maybe even the crio imaging tool for the year before and got an error that I do not remember off the top of my head.
The other problem we had which probably seems obvious to most people but I will throw it out there any ways because a new team member failed to do it and it caused problems is entering the team number in the imaging tool.
No guaranties, just the problems and the solutions my team ran into when we imaged our cRIO.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 20-01-2011, 22:44
mattiej's Avatar
Programmer Guy
Re: cRIO Problem
Thanks for the help, but we finally got it resolved. The issue was with the firewalls. Error 60, then sequentially error 1 are firewall errors. Just if anyone else wants to know.
