Go to Post Guess i don't know what the secret weapon is, but i bet if it can be wedge shaped it is. - Chris [more]
Unread 19-01-2011, 09:42
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: 816's 2011 Frame (Teaser?)
Originally Posted by sdcantrell56 View Post
Yeah man we decided just to use 2 of the 550's to power our elevator since they are so equal in power and the transmissions were available
I ran some numbers with both the 550's and the 775's and while the 550 was capable of doing what we needed it to do, we felt that the added robustness of the 775 was something that we wanted.
Originally Posted by MattC9 View Post
Sweet!!! what made yall decide on 6WD?
There was really no reason that we could come up with to not build a 6WD. The field is flat, relatively unobstructed, and the game called for mobility, speed and pushing power (Or at least the ability to hold your ground), so we felt that 6WD was the best option to fit all of those.
Originally Posted by Brandon Holley View Post
What configuration (ie: gear ratios) of the Supershifter are you gonna be running? aka: what speeds are you shooting for?
-Brando
We're running the stock gear ratios on the Super Shifter. With a 6" wheel, we're looking at a low Gear of somewhere around 5fps and a high gear somewhere around 13fps after adjusting for efficiency and all that fun stuff.
-Dustin Benedict
Unread 19-01-2011, 16:54
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
dustin.... looking forward to seeing you guys in jersey. im assuming you are using 6" x 1" plactions, looks good. should hold up to some solid challenges.
hoping for a strong season from you guys again ill get something up for 2016 on here soon...
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
Unread 19-01-2011, 20:13
Are you building the same lift as your 08 bot?
Unread 20-01-2011, 08:04
thefro526's Avatar
Mentor for Hire.
Kinsuk, Thanks for the kind words. Yes, we are planning on using 6"x1" AM Plaction wheels, just like we used last year. I've yet to find anything better in the same price range that has been proven to handle the abuse of FRC.
Also, I don't know if Tyler told you or not, but our Practice field will be available Starting on January 31st, I'd love it if you guys came down for some scrimmaging.
We talked about it, and then ruled out the idea once the 60" cylinder was ruled as 84". Problem with that lift was that it was heavy as all hell and there wasn't really an easy way to lighten it up.
-Dustin Benedict
