Go to Post I can't believe it someone is talking about next years game rationally! - jamie_1930 [more]
Unread 20-01-2011, 10:22
Nailo2532 Nailo2532 is offline
FRC #2532
Nailo2532 is an unknown quantity at this point
holonomic drive/ mecanum wheels
Before I loaded the 2011 labview software to my computer I saw the holonomic drive vi example, but with the 2011 labview I can no longer find the vi. I am attempting to program mecanum wheels and have heard that I should use the holonomic drive vi, if someone has something better than this I would appreciate it, or if someone has the location of the vi. This is my teams first year using mecanum and we would also appreciate any tips people have on using mecanum wheels.
Unread 20-01-2011, 11:21
Re: holonomic drive/ mecanum wheels
It's in the RobotDrive functions subpalette. If you don't see it, you might not have installed the LabVIEW software update properly.
Unread 20-01-2011, 14:28
FRC #2532
I think I was mis understood, I am looking for the vi example. Not the programming block.
Unread 20-01-2011, 16:05
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
I do not see one but it isn't much different from an arcade or tank drive (with using the VI given) aside from that instead of 2 axes you need 3 axes (from the joystick). Your X value goes to the x your Y value goes to your y and your 3rd axis goes to the rotation. After that you just need to test to see that everything is going the right direction by firing up the robot and running it.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 20-01-2011, 16:40
FRC #2532
I don't see an x and y spot on the holonomic drive, it has magnitude, direction, and rotation. should it be like this?
Unread 20-01-2011, 16:48
You're looking at the polar version. Switch to the Cartesian version.
Unread 20-01-2011, 19:46
FRC #2532
I hooked it up to servos and it worked thanks
