Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 16-01-2011, 21:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: RS550 Enough Power?
Originally Posted by Eigenvector View Post
I'd recommend going with the window motor though, they've got much higher torque.
And MUCH MUCH less power....
Unread 16-01-2011, 21:18
It's power that counts, not torque. You can always get more torque by changing the gearing.
The RS550 has 10 times the max output power of the window motor.
Unread 16-01-2011, 21:23
Best Available Data
FRC #1778 (Chill Out!)
Originally Posted by squirrel View Post
We used a little 540 type Banebots motor and 125:1 transmission and 8:1 ratio chain drive to move an arm up and down for RacknRoll in 2007. Worked fine, lasted all season. But we cheated and used a gas spring to help support the arm, so the motor didn't have to work hard. I recall it took less than two seconds to raise the arm.
Oh cool! Did you ever strip a stage in the planetary or fry a 540? Any idea about how much your arm weighed?
Unread 16-01-2011, 22:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I bought several spare motors and a couple spare gearboxes...that was money wasted, as we never had any problems with it at all. I don't remember what the weight was, but with the gas spring assist, which mostly prevented back driving the motor, it takes very little effort to lift the arm. Maybe a couple pounds a foot from the pivot.
Unread 17-01-2011, 01:00
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
I've go to agree with Jason ( dtengeneering). We too like worm drives--especially for lifting. You don't have to worry about backwalking, hence, no maintaining current to maintain height. Pairing up the windows motors with the correct sprocket ratios worked well for us in '07. We're using a much, I mean MUCH, heavier arm this year so we'll use gas springs too.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 17-01-2011, 14:35
Alienvin's Avatar
Alienvin Alienvin is offline
Technically Speaking, Who Knows....
AKA: Vinny
FRC #1546 (Chaos Inc.)
Alienvin is an unknown quantity at this point
Good Afternoon Jim,
Let's see how my math works out here.
If I go on 1/4 of the Stall Torque 4.4 in-lbs, which is 1.1 in-lbs. And my full extension of the arm is 56". 36" from the initial pivot to the second pivot which has a 1'6" extension that is the manipulator. So throw out 56" if it is FULLY Extended, the entire design weighs 10lbs, (I am going to build it so it weighs 7lbs) but let's give my self some breathing space. That'll give me 560in-lbs. So I'll need a minimum of a 560:1 Gear Ratio. Going on I am running the RS550 Motor on 1/4 loss in rpms. So if I put a Banebots 132:1 Gearbox on it, it will bring me down to 113.64RPM, then with an additional 6:1 or 5.4:1 or 4.8:1 reduction I will have my Ratio from 791.97:1 (18.94RPM) or 719.93:1 (21.04RPM) or 633.45:1 (633.45RPM).
I spoke to a Tech at Banebots this morning discussing efficiency with their gearboxes, they said using a 256:1 Gearbox would work, but also recommended that I stay lower in 104:1 to 132:1 Gearbox Ratios for better results.
What do you think Jim?
Vinny
2010 Regional Finalist Award Winner - SBPLI Long Island Regional
2007 Kleiner Perkins Caufield & Byers Entrepreneurship Award Winner - SBPLI Long Island Regional
2006 Johnson & Johnson Sportsmanship Award Winner - SBPLI Long Island Regional
2005 Rookie All-Star Team Award Winner - SBPLI Long Island Regional
http://teacher.baldwinschools.org/robotics
Unread 17-01-2011, 14:42
MrForbes's Avatar
AKA: Jim
I think it might work. As mentioned, it will probably be able to be backdriven, meaning the arm will fall down unless you keep providing power to the motor...but the motor doesn't like to sit in one place with significant power applied to it (the armature has little thermal mass and doesn't have any cooling when the motor is not turning).
The motor should be able to move the arm OK, without overloading the motor.
And if you make a PID loop that does not have enough damping, it'll be running up and down all the time....
I'm going to suggest to our team that we put the modern control system on our 2007 robot, so they can learn how to program the arm.
Unread 20-01-2011, 11:20
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Originally Posted by Alienvin View Post
So Jim,
I'm looking at the RS-550, 19300 RPM Free Speed with a Banebots Gearbox with a Gear Ratio of 256:1, then maybe a 10T off the Banebot Gearbox to either a 48T, 54T, or 60T Sprocket attached to a 3' Arm Extension that at the end of it has a 1'6" arm extension that to has a gearbox setup on the end of it. All in all I would like to keep the entire weight to the arm under 7lbs.... What you think?
Be very careful in how you use a 256:1 Banebots. They are very easy to destroy. Even with a 550 motor, you get LOTS OF TORQUE at the output, not to mention what you get with a 775 or Fisher Price motor.
Team 1062, The Storm, 2003
Unread 20-01-2011, 12:01
Best Available Data
For more anecdotal 256:1, we used them for this actuation. There were two of them (one powered the "stick" that pushes it up, the 2nd rotated it forward to lock it out. One of them was cantilevered, the other was not. The cantilevered one failed at 6:30 PM on Thursday, so we luckily got a chance to fix it without any intervening matches. We un-cantilevered the output, and it did not fail for the rest of the tournament. We never needed to replace the one which was not cantilevered to begin with. There were probably 50 cycles on the one we replaced, and 100+ on the one that was not replaced.
There was *a lot* of torque in that set up. We wouldn't do it again (apparently our lead mentors were betting in the stands on whether it would fail every single lift), but the BB did hold up. We must've used the 550 and 540, because both FPs were in the toughbox on top of the arm.
Just another data point.
Unread 20-01-2011, 12:14
We tried using one with a Fisher-Price for our arm rotation in 2007, and destroyed it instantly. In retrospect, we should have known better, given all the power of the F/P and moment of inertia of the arm.
If used properly, and with less powerful motors than the F/P, the 256:1 planetaries are fine. Also, I think the current ones are stronger than the ones we broke in '07.
