Go to Post Remember, FIRST is merely a means to an end - the end result being that we completely change the world for the better. - RogerR [more]
  #31   Spotlight this post!
Unread 20-01-2011, 09:12
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Never Do This, and Other Good Ideas Gone Bad
In 2005 we used casters on the front of our robot. When we would go to the loading stations if they got on the raised part of the loading station we would get stuck.
I have seen many instances of caster problems on robot so "no casters is a fixed rule for us.
#1 No casters
#2 No scissor lifts.
#3 No elevators (I have seen many instances of very effective elevators but not from us)
#4 If balls are the game piece they must always be under the influence of at least one moving part.
  #32   Spotlight this post!
Unread 20-01-2011, 09:41
Brandon Holley's Avatar
Lots of good ones out here already, but my personal favorite:
NO SET SCREWS
I will never ever trust a set screw alone to retain something to a shaft on a FIRST robot.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #33   Spotlight this post!
Unread 20-01-2011, 10:50
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
NO SET SCREWS
-Brando
Retain, or transmit torque?
Relying on set screws to transmit torque on an FRC robot is almost always a bad idea (except for things like potentiometers), but we've used them dozens of times to hold something in place (laterally along shaft) without any problems. That being said, I prefer to design around them, and either use Delrin spacers, stepped shafts, tapped shaft ends, E-clips, or roll-pins to avoid them. If we need to use them, we almost always drill for two set screw holes 90 degrees apart, use Loctite threadlocker, and only use the cone-tip set screws.
Art Dutra IV
世上无难事,只怕有心人.
  #34   Spotlight this post!
Unread 20-01-2011, 10:53
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
NO SET SCREWS
-Brando
What about trusting Set Screws on FRC Mini-Bots? The Mini-bot FTC kit was full of set screw based components.
  #35   Spotlight this post!
Unread 20-01-2011, 11:17
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
1.) Do not gear a drive train for >10 fps if it has less than 3 CIMs' worth of power. It does ok in a straight line, but even with a 6WD drop center it had some difficulty turning 145lbs.
2.) Do not use 80/20 for a triple-compound elevator that has 20lb worth of manipulator and game piece on the top stage. The stresses on the bottom stage will increase the friction in the 80/20 linear slides too much.
3.) Do not make a 'naturally articulating' drive train. The drive train needs to be rigid or controlled in all aspects at all times. Our 'naturally articulated' drive train pods worked 'fine' in 2010, yet they didn't quite perform as expected. By the time we were testing it, we didn't have time to change to a new design.
4.) Do not design a multi-configuration 'automode' that is configured via the little switches on a Classmate PC. The little buttons are just too durn small.
5.) Elevators that have multiple pre-programmed positions + override/tuning are great in theory, yet are very difficult to master from a controls perspective. We're going to do a multi-position elevator for the driver again, yet with a very nice twist to add some autonomy.
  #36   Spotlight this post!
Unread 20-01-2011, 11:19
JesseK's Avatar
FRC #1885 (ILITE)
They will require some tightening eventually. On the kids' 9:1 double shooter last year in FTC, we had to tighten the set screws about once every 3 matches.
  #37   Spotlight this post!
Unread 20-01-2011, 11:29
If I have no other choice I will give in to using a set screw for retaining only. I much rather use spacers, e-clips, pins, you name it before I'd choose a set screw though. Obviously transmitting torque is a massive no-no.
-Brando
  #38   Spotlight this post!
Unread 20-01-2011, 11:36
I really dislike the way the FTC kit handles transmitting power through the shafts with setscrews, amongst many other things in the kit. However, given the minibot rules and such, I'm sure many teams are going to be pigeon-holed into using the set screw solution. I'm sure it will work well for most teams, and some loctite here and there may help avoid any complications...still doesn't mean I have to like it.
-Brando
  #39   Spotlight this post!
Unread 20-01-2011, 12:34
Racer26 Racer26 is offline
1075's no-no's are:
NO SET SCREWS (too many things have slipped in the past)
NO POTENTIOMETERS (code runs away and busts them, alleviated by using a 10turn pot, or encoder.)
NO BEVEL/MITER GEARS (this stems from our rookie year where we used one cantilevered on the end of a 4" shaft, which shredded, and cost us the 2003 Canadian Regional because we couldn't play in the finals, because the gears were toast)
  #40   Spotlight this post!
Unread 20-01-2011, 12:40
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
From the Controls Team:
NO potentiometers - use multi-turn or continuous turn pots or encoders
NO limit switches engaging fast moving arms or other robot parts - use magnetic reed switches instead
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #41   Spotlight this post!
Unread 20-01-2011, 12:43
Chris is me's Avatar
AKA: Pinecone
Using set screws for retainment is IMO just as bad, when you could be using snap rings.
  #42   Spotlight this post!
Unread 20-01-2011, 13:16
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Do not use window motors for lever arms.
339 tried this both in 2007 and 2008 with the same results: we ended up switching from a motor to a pneumatic cylinder on the day before ship.
Go directly to queue. Do not pass pit.
  #43   Spotlight this post!
Unread 20-01-2011, 13:19
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Never rely on pneumatics alone as a fast, pushing force. Our team learned this lesson the hard way in '09.
Never forget to leave room for electronics and then try creating space the night before ship.
Also, our team has never had much success with belt systems.
  #44   Spotlight this post!
Unread 20-01-2011, 16:18
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Another stopgap measure (if you can't take advantage of any alternatives, and need to use the setscrews) is to carefully centerpunch and drill a small indentation in the shaft, for the setscrew to sit in. (Alternatively, you can file a flat on the shaft.) When combined with some purple or blue Loctite (on the screw threads only; not on the shaft!), this will generally make an acceptable joint. It's still going to be limited, but it's just about the best you can do.
(Occasionally, wrapping something around the hub to keep the setscrew from falling out when it loosens can be marginally useful. It won't transmit power with a screw loose, but at least you won't have to hunt for the screw.)
  #45   Spotlight this post!
Unread 20-01-2011, 16:23
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
For what it's worth, the Tetrix-brand shafts have a flat along their entire length.
--Madison--
...down at the Ozdust!
