Go to Post the point is that FIRST is successful, in so many different ways - Pamela [more]
Unread 19-01-2011, 21:02
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Unhappy Java CAN-Bus Issue
We have been having some trouble with the CANJaguars.
I have updated firmware, assigned IDs, and tested motors using BDC-Comm.
The problem lies in running the code. When I enable the robot, I get this:
[cRIO] NI-VISA Server 4.5 started successfully.
[cRIO] task 0xe63670 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
[cRIO] FPGA Hardware GUID: 0x2EAA5E59CAF1A8A966853A011B61CC91
[cRIO] FPGA Software GUID: 0x2EAA5E59CAF1A8A966853A011B61CC91
[cRIO] FPGA Hardware Version: 2011
[cRIO] FPGA Software Version: 2011
[cRIO] FPGA Hardware Revision: 1.5.3
[cRIO] FPGA Software Revision: 1.5.3
[cRIO] * Loading StartupDlls: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2011 FRC, Jan  6 2011, 09:47:42
[cRIO]
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 8.6.1f3
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Jan 17 2011, 16:12:19
[cRIO]
[cRIO] FPGA Hardware GUID: 0x2eaa5e59caf1a8a966853a011b61cc91
[cRIO] FPGA Software GUID: 0x2eaa5e59caf1a8a966853a011b61cc91
[cRIO] edu.wpi.first.wpilibj.can.CANNotInitializedException
[cRIO]     at edu.wpi.first.wpilibj.can.CANExceptionFactory.checkStatus(CANExceptionFactory.java:44)
[cRIO]     at edu.wpi.first.wpilibj.can.JaguarCANDriver.sendMessage(JaguarCANDriver.java:29)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.sendMessage(CANJaguar.java:567)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.getTransaction(CANJaguar.java:630)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.getFirmwareVersion(CANJaguar.java:1192)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.initCANJaguar(CANJaguar.java:240)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.<init>(CANJaguar.java:267)
[cRIO]     at edu.wpi.first.wpilibj.templates.RobotTemplate.robotInit(RobotTemplate.java:30)
[cRIO]     at edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:73)
[cRIO]     at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:154)
[cRIO]     in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO]     at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(64)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1506)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
[cRIO] Default IterativeRobot.disabledInit() method... Overload me!
[cRIO] Default IterativeRobot.disabledContinuous() method... Overload me!
[cRIO] Default IterativeRobot.disabledPeriodic() method... Overload me!
[cRIO] Default IterativeRobot.teleopInit() method... Overload me!
[cRIO] java.lang.NullPointerException
[cRIO]     at edu.wpi.first.wpilibj.templates.RobotTemplate.teleopPeriodic(RobotTemplate.java:46)
[cRIO]     at edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:141)
[cRIO] Default IterativeRobot.teleopContinuous() method... Overload me!
NullPointerException repeats...
Here is my code:
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.CANJaguar;
import edu.wpi.first.wpilibj.SpeedController;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class RobotTemplate extends IterativeRobot {
    Joystick gp = new Joystick(1);  //GamePad
    CANJaguar leftA;
    CANJaguar leftB;
    CANJaguar rightA;
    CANJaguar rightB;
    public void robotInit() {
       try {
         leftA = new CANJaguar(2);
         leftB = new CANJaguar(3);
         rightA = new CANJaguar(4);
         rightB = new CANJaguar(5);
        } catch(Exception e) {
            e.printStackTrace();
     * This function is called periodically during operator control
    public void teleopPeriodic() {
        try {
         //Tank Drive, Gamepad
         try {
            leftA.setX(gp.getRawAxis(2));
            leftB.setX(gp.getRawAxis(2));
            rightA.setX(gp.getRawAxis(4));
            rightB.setX(gp.getRawAxis(4));
        } catch (edu.wpi.first.wpilibj.can.CANNotInitializedException cnie) {
            cnie.printStackTrace();
Any help appreciated!
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 19-01-2011, 22:23
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: Java CAN-Bus Issue
Is that the entire log?
I dont see where the can plugin is being loaded . . .
did you re-image the crio to v25 with the can plugin selected?
Unread 20-01-2011, 01:01
That is an excerpt. I cut some out for space.
The plugin loads fine. I have reimaged it with the 2011 Serial to CAN driver, V25.
I am sure the cables are fine, as I have salvaged them from our Breakaway bot.
Everything is fine, up until the point where I enable the robot.
If you need any more info, I can try to do it again tomorrow.
Thanks In Advance!
[FF] FIRST Pick
Unread 20-01-2011, 10:26
AKA: Bryant
Thanks In Advance!
If you look carefully one of the jags doesn't initialize properly which is called BEFORE you enable it. Are you sure your jags are numbered 2 3 4 5 instead of 1 2 3 4?
Unread 20-01-2011, 13:43
I am 90% sure that I have them numbered 2-5. I will check when I am in our shop in a few hours. Thanks!
[FF] FIRST Pick
Unread 20-01-2011, 21:09
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The CANNotInitializedException means only one thing. The driver plugin is not registered with the system. Double check that you are actually loading the driver plugin.
-Joe
Unread 20-01-2011, 21:15
Thanks you two. I've reimaged it and it works now!
[FF] FIRST Pick
