Go to Post The holiday season is formally known as "kick-off rendering season" - dlavery [more]
Unread 20-01-2011, 13:44
spope14 spope14 is offline
Team Mentor 3585
AKA: Scott Pope
FRC #3585 (Rogue Robots)
spope14 is a jewel in the roughspope14 is a jewel in the roughspope14 is a jewel in the rough
OK, been searching, Jaguars and application and control panel
New to this, sorry. I am just wondering about the application of the Black jaguars and also have some questions regarding the driver control panel - is it a PC or a special part that is purchased.
Sorry to sound naive to this all, just getting started.
Unread 20-01-2011, 13:48
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: OK, been searching, Jaguars and application and control panel
Black jaguars are speed controllers. They are used to vary the speed of a motor, by adjusting the voltage. 2 of them came in the KOP.
I think your refering to the Driver Station when you say driver control panel. If you are a rookie team, you should have gotten a classmate laptop in the KOP this year. If your a veteran team, then you got one last year, and are expected to use that, or any other laptop as a driverstation.
The Driver Station can be any computer, the only requirement is that it can run the Driver Station software, and that it has an ethernet port.
