Go to Post FIRST is all about going past theoretical limits. - Foster [more]
Unread 20-01-2011, 16:45
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Bumper rules
What is the legal height of the bumper from the floor?
is this bumper configuration is legal?
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 20-01-2011, 16:53
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: Bumper rules
Attachment 9751
The "bumper zone" must be between 1" and 7" from the ground... Since the bumpers are 5" tall, that gives you one inch to play with.
"BUMPER ZONE – the volume contained between two virtual horizontal planes, one inch above the floor and seven inches above the floor."
Without dimensions it's hard to tell if that configuration is legal. But as long as those gaps are all less than 8" long, you're good.
"The BUMPER backing must be supported by the structure/frame of the ROBOT (i.e. the gap between the backing material and the frame must not be greater than 1/4” and no section of BUMPER greater than 8” may be unsupported). See Figure 3-3."
Best of luck to your team!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 20-01-2011, 16:54
Re: Bumper rules
The Bumper Zone is defined in Section 1.6 (along with all the other definitions). Bumpers must be in the Bumper Zone.
Your configuration should pass inspection if your supports are < 8" (20 cm) apart or < 1/4" (0.635 cm) deep per <R07-K>.
Unread 20-01-2011, 20:31
azndarkvader azndarkvader is offline
None #3473
azndarkvader is infamous around these parts
Re: Bumper rules
hey guys I'm new to frc but I have a question. what is the best way to mount the bumpers for the kit of parts?
Unread 20-01-2011, 20:46
Re: Bumper rules
You'll probably want a standoff, but some blind nuts in the back side of the bumper plywood and some long bolts should do the trick. The standoff would be to keep the bolts from becoming hard to get to in the C-channel.
Just make sure that the bumpers will be in the bumper zone when mounted.
