Go to Post I'm still trying to find a way to get FIRST to dump the Chicken Dance song. :p - Koko Ed [more]
Unread 20-01-2011, 16:37
CeeCee McShane's Avatar
CeeCee McShane CeeCee McShane is offline
FRC #3585 (Rogue Robots of 4-H)
CeeCee McShane is an unknown quantity at this point
Super Rookies
We are Team 3585 in Claremont NH, and we are struggling with getting our programmers up and running in Labview. We've used the NI documentation and online tutorials, but are looking for some quick start instruction. Any suggestions? Our programmers are getting pretty discouraged! Thanks!
Carol
FIRST Team 3585 - The Rogue Robots of 4-H
“Faith is taking the first step even when you can't see the whole staircase.” ― Martin Luther King Jr.
Unread 20-01-2011, 16:42
celenacrews's Avatar
celenacrews celenacrews is offline
FRC #3556 (GET SMART)
celenacrews is an unknown quantity at this point
Re: Super Rookies
http://www.frcmastery.com/labview-fo...robot-success/
Unread 20-01-2011, 17:18
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Re: Super Rookies
I am a team member of 3585 too, and as a programmer am wondering what the 2 different parts of the programming(Front panel, and Block diagram) mean, what they do, and how you program them using the pallete. I did FLL last year so if you can give me an idea of how(if at all) NI Labview compares to NXT, that would be helpful.
Please help, I am completly lost.
Unread 20-01-2011, 21:39
tagayoff's Avatar
tagayoff tagayoff is offline
FRC #3512
tagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the rough
Smile Re: Super Rookies
Go to theFRCMastery site
and go through the 7 steps to robot sucess.
Unread 21-01-2011, 00:00
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Super Rookies
The front panel shows dials and switches and buttons. It's the inputs and outputs of your function, generally. However, for FRC you don't ever really use the front panel for most things, because the inputs and outputs are done with just the "run motor" and "get joystick" commands.
The block diagram is where the programming is done. All the thin lines are called "wires" and they connect "functions." The wires should be a familiar concept to what NXT has (I think, I just use LabVIEW for programming NXT). They are variables: numbers that you modify with functions. Functions are basically things to modify the variables, but for FRC you'll use many that take the wires in and run motors using them.
For example, when you go to robot main, find teleop.vi. In there, you'll see some sort of "get joystick" with a wire coming out of it, which goes into an "arcade drive" function. The get joystick function returns wires that give the x and y positions of the joystick, and the arcade drive function takes x and y positions and runs the motors. These are a perfect match, so all their wires go together.
I suppose you're probably wondering what the purple wires going into the functions are also. These are "devise references", and basically tell the arcade drive function which motors to run (is it the ones connected to port 2 or port 3?)
Unread 21-01-2011, 08:50
Re: Super Rookies
You already have some good advice. In NXT, the only thing you build are diagrams. The diagrams look a bit different, but work basically the same. In reality, the framework of FRC allows you to build your program without ever editing a panel. You may find it very useful to place some control or indicators on the panel so that you can see and change values as your robot is running.
Please look at the FRCMastery training, work through some examples, and ask plenty of questions.
Greg McKaskle
Unread 21-01-2011, 09:38
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Super Rookies
Don't forget the 2010 videos. They offer a lot of help on LabVIEW basics.
Mike B
Unread 21-01-2011, 09:51
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Re: Super Rookies
This is an analogy that I was taught that I think will help you with understanding what the front panel and block diagram are if you don't already.
In a car the dashboard/driver's seat is like the front panel, it contains all your inputs in to the engine (wheel, gas peddle, knobs, ect) and all your outputs from the engine (speedometer, RPM, check engine, ect). That's what the front panel is, it (in addition to joysticks and stuff like that) is your interface with your program.
The block diagram is like a view under the hood. When you look under the hood you see various units and different types of wires and tubes connecting them. Each component (engine, radiator, oil pump, ect) is like a .vi and each wire or tube is like a wire.
Another important thing to know is that the type of things you can do and create on the front panel and block diagram are different. For example you can only create a light or switch on the front panel (a corresponding block will automatically appear on the block diagram), and can only create wires, or references to other .vis (like joystick get) on the block diagram.
After that if you want to learn more about labview dissect the examples of code that FIRST gives you and just click around a lot. Hopefully this was helpful and not overly long winded, good luck!
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 21-01-2011, 10:08
Re: Super Rookies
Thank you everyone. This is great.
Unread 21-01-2011, 11:10
MaxMax161's Avatar
Allegedly Useful
AKA: Max Llewellyn
Re: Super Rookies
Any time, happy to help. If you have any more questions, or need help with somthing more specific feel free to shoot me an email and I'll get back to you as soon as I can.
