Go to Post The game is as much a competition of strategies as it is of robots. There is never any one "best strategy." If teams choose to use this as their strategy, find one that will beat them. - srjjs [more]
Unread 20-01-2011, 17:19
Rosemount2606 Rosemount2606 is offline
FRC #2606
Rosemount2606 is an unknown quantity at this point
Help setting up Windriver 2011
Our team is having trouble setting up Windriver for 2011. Last year we set up the 2010 windriver software on the classmate, and this year we are having problems getting windriver working. We have searched the forums and tried using the tutorials we found, but none of them have seemed to work. Many mention a 2011 installation disk which we dont have, pointing us to a file to get the LAC, we have the file in our 2010 disk, but it doesn't work because the 2010 version is out of date. We have installed the new image and run every other update besides net beans for the classmate.
We would appretiate any help, and could use as much detail in a response as possible. We thank you very much for helping.
Unread 20-01-2011, 19:12
Apsurette Apsurette is offline
AKA: Alex Surette
FRC #2059 (The Hitchhikers)
Apsurette is an unknown quantity at this point
Re: Help setting up Windriver 2011
Did you check your First Scholarship packet for the installation disk? That's where we found it.
Unread 20-01-2011, 19:38
FRC #2606
thanks, that got filed away before we had a chance to look through it, and we didn't realize that it contained the disc - that helps a lot!
p.s. you are awesome.
Unread 20-01-2011, 21:06
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
There's also a problem with the path and the WPILIB... If you can't get code to compile those are the reasons... For some reason even with the updates the WPILIB isn't there and the path is messed up. You also need to make sure you get the update because it has the FIRST tools you need to deploy your code.
Unread 22-01-2011, 11:20
FRC #2606
Well, after installation, we uncovered another problem. After a few hours of troubleshooting, I come back for more help. The installation from the 2011 windriver disk was successful, but we cannot find the application for windriver itself, even after installing the updates found on the first website. If there is something we missed, please let us know. Thank you.
