Go to Post If you don't manage weight from the beginning, weight will manage you at the end. - charrisTTI [more]
Unread 19-01-2011, 22:57
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
Angry activation code?
hey, let me start off saying, this is our first year attempting to use c++ to move the robot. we probably wont be using it in the competition either, but, some of our programmers and i want to use c++. we have one.... slight... problem... we cant find the activation code for windriver... we are using labview this year, so it's not life or death, but, it would be nice. the LAC area is not pre-populated as the instilation instructions say, nor is it on the sleeve. please help?
this is exactly what it says in the instructions:
"The “User Information” dialog window should appear, with a pre-populated License
Activation Code (LAC)."
"you can build a perfect machine out of imperfect parts" -Urza
Unread 19-01-2011, 23:58
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: activation code?
When asked to enter the activation code, choose "Permanent activation" and browse the root folder of your DVD drive for a txt file FRC_2011_Install.txt. That's the file containing the activation keys.
Unread 20-01-2011, 17:50
techkid86's Avatar
Magic Programer
FRC #3044 (0xBE4)
thank you very much. i'm going to try that asap
