Go to Post (The wheels) need to be green anodized, and then assembled with yellow anodized spinners. ... and then, on the spinners, you can etch "JVN is a dweeb". That would be cool. - Andy Baker [more]
Unread 20-01-2011, 19:45
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Using encoder with jaguar
Originally Posted by demosthenes2k8 View Post
Is there any example code that shows how to do this?
If there was example code for everything, FIRST wouldn't exist.
Learn how to use the encoder, learn how to use the Jaguars, research on closed-loop controllers. Do your homework!
Unread 20-01-2011, 22:04
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
It's possible, and example code exists (see the CANJaguar project on FIRST Forge) but you'll need to use CAN instead of PWM control for your Jags, which is a whole 'nother can of worms.
Unread 20-01-2011, 22:13
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Oh, we're already using CAN, so that's not a problem.
We think we ended up finding out what we needed, we just have to initialize it with kSpeed, set the speed reference, and convert joystick values into RPM.
GSR Dean's List Finalist 2011
Unread 20-01-2011, 22:47
Don't forget to set your PID values..
Unread 20-01-2011, 23:55
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Sorry, using velocity or another other closed loop control on the Jaguars has been deemed illegal. See here: http://www.chiefdelphi.com/forums/sh...43#post1004743
Unread 21-01-2011, 11:34
AKA: Matt Soucy
Ouch. Welll...I guess that settles it, then.
Unread 22-01-2011, 11:44
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
it is allowed from what i've seen, check team update 4
http://usfirst.org/uploadedFiles/Rob..._Update_04.pdf
Unread 22-01-2011, 11:45
AKA: Matt Soucy
Yeah, we found that. Thank you!
