Go to Post Didn't know the details about the battery. In the past it was just a black (grey) box with two terminals...use...recharge...use..recharge. - cbolin [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
  #91   Spotlight this post!
Unread 20-01-2011, 14:31
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Minibot climb rate
Originally Posted by JesseK View Post
I'm calling shenanigans on a minibot under 3 seconds. Reliably deploying and shutting off while making the climb in under 3.5 seconds is even improbable @ 14V, perfect peak power, and the minimum 3.5lbs it takes for the battery, motors, switches, [custom] wheels, and just 1 ft. of attachment structure held together with magic (or rivets...).
3 seconds is doable. I don't think Frenchie is implying that the deployment time is included in their claim.
  #92   Spotlight this post!
Unread 20-01-2011, 15:11
perry3018 perry3018 is offline
FRC #1543
perry3018 is an unknown quantity at this point
Is the mini bot allowed to have springs on it
  #93   Spotlight this post!
Unread 20-01-2011, 15:17
yp673mp's Avatar
yp673mp yp673mp is offline
Captain America
AKA: Marek
FRC #2851 (Crevolution)
yp673mp is an unknown quantity at this point
We just got 2.93 seconds with our mini bot...in heavy mode. We haven't even started shaving weight off.
FIRST is a sport of the mind...and we're all insane!!!
Crevolution will be at Waterford and Troy Districts!
2012 Waterford District Champions (Thanks 67 & 469)
  #94   Spotlight this post!
Unread 20-01-2011, 15:28
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
our minibot is going up in about 2.8 seconds. Not including deployment time, so it is doable, but deployment is where the race will be won.
  #95   Spotlight this post!
Unread 20-01-2011, 16:40
acrease77's Avatar
acrease77 acrease77 is offline
AKA: Alex Crease
FRC #1155 (SciBorgs)
acrease77 is an unknown quantity at this point
theres no springs allowed on the minibot or for deployment--team update #1 said no stored energy in deployment.
and how did you ever get it in under 3 seconds if not with a spring/launcher thing??
  #96   Spotlight this post!
Unread 20-01-2011, 16:48
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The TETRIX motors are actually about 16W at peak power, not 8.43W as the spec sheet suggests. Surprisingly fast times are feasible.
Art Dutra IV
世上无难事,只怕有心人.
  #97   Spotlight this post!
Unread 20-01-2011, 17:06
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Getting similar times on direct drive prototypes and 2-1 gear ratio prototypes... we are assuming similar times is due to gearing inefficiency and the added weight of all the extra gears, spacers, etc... The question is, how much better can we expect if we lighten up the Tetrix gears and improve gear alignment???
  #98   Spotlight this post!
Unread 20-01-2011, 17:31
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Strictly based on calculations and the specifications available, the difference in times when directly driven and when a 1:2 gearing increase is added is only 1 second.
The calculation with the gearing did not include the additional weight of the extra hardware and gears requires to add the gears.
When I calculated with the weight added, I only see a difference of .8 seconds.
Therefore, I am not surprised in the least that your times are very close. Add in a factor of human error if manually timing, and you could easily have a dead heat.
So, would lightening the hardware help? You bet!
  #99   Spotlight this post!
Unread 20-01-2011, 18:17
chemipanda chemipanda is offline
Budha
FRC #0240 (TEMPEST)
chemipanda is an unknown quantity at this point
I know this is a bit off topic but what size wire do you happen to use for wiring the motors?
thanks
  #100   Spotlight this post!
Unread 20-01-2011, 18:24
Chris is me's Avatar
AKA: Pinecone
So... we saw smoke when we made our bare bones minibot try to climb, with a modest overgear (0.5:1). These things can't be stalled for even a half second, apparently? I have no idea what smoked or whether or not the motors still worked, but if the motors are that delicate...
  #101   Spotlight this post!
Unread 20-01-2011, 21:04
E2207 E2207 is offline
FRC #2207
E2207 is an unknown quantity at this point
Originally Posted by Chris is me View Post
Surgical tubing that does not contribute to the vertical motion of the robot is allowed. The best exampe I can think of is a surgical tubing tied gate latch.
Does rule include using surgical tubing as a drive belt and a friction surface on the wheel?
  #102   Spotlight this post!
Unread 20-01-2011, 21:51
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
We smoked a motor hitting the top of the pole and not shutting off...probably a maximum of about 3 seconds of full voltage on a jammed motor.
This happened on the very first occurrence.
My suggestion is make sure you put in the motor cutoffs at the end of the race or make sure your wheel contacts are slippery enough to keep that motor turning.
I'm glad we ordered two extra motors. I expect many teams will fry motors before getting a working minibot.
BTW, our prototype uses solder on the motor contacts and uses standard tab and receptacle electrical connectors- not wire nuts.
If they didn't want us to use solder, then it would have been nice for them to supply Tetrix "DC Motor power cables". http://www.legoeducation.us/store/detail.aspx?ID=1629
  #103   Spotlight this post!
Unread 20-01-2011, 21:54
AKA: Pinecone
Nope - I meant "surgical tubing to store energy" rather than "surgical tubing". If the tubing isn't storing energy there's no rule broken.
  #104   Spotlight this post!
Unread 20-01-2011, 22:03
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
as a referance, Today, team 2200 made it to the top (no top plate yet) of the pole in 2.6 seconds, with a minibot that weighed 4.9lbs. and we still have LOTS of room to save weight.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
  #105   Spotlight this post!
Unread 20-01-2011, 22:37
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
What type of gearing are most of you advanced minibotters using?
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
