Go to Post I think overcoming obstacles together builds a stronger team. - MissInformation [more]
Unread 20-01-2011, 19:14
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Using encoder with jaguar
My team saw in a PDF that it was possible to use an encoder connected to a jaguar to regulate the speed. Unfortunately, we haven't been able to find any information about actually DOING this in C++. Is there any example code that shows how to do this?
GSR Dean's List Finalist 2011
Unread 20-01-2011, 19:45
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Using encoder with jaguar
If there was example code for everything, FIRST wouldn't exist.
Learn how to use the encoder, learn how to use the Jaguars, research on closed-loop controllers. Do your homework!
Unread 20-01-2011, 22:04
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
It's possible, and example code exists (see the CANJaguar project on FIRST Forge) but you'll need to use CAN instead of PWM control for your Jags, which is a whole 'nother can of worms.
Unread 20-01-2011, 22:13
AKA: Matt Soucy
Oh, we're already using CAN, so that's not a problem.
We think we ended up finding out what we needed, we just have to initialize it with kSpeed, set the speed reference, and convert joystick values into RPM.
Unread 20-01-2011, 22:47
Don't forget to set your PID values..
Unread 20-01-2011, 23:55
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Sorry, using velocity or another other closed loop control on the Jaguars has been deemed illegal. See here: http://www.chiefdelphi.com/forums/sh...43#post1004743
Unread 21-01-2011, 11:34
AKA: Matt Soucy
Ouch. Welll...I guess that settles it, then.
Unread 22-01-2011, 11:44
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
it is allowed from what i've seen, check team update 4
http://usfirst.org/uploadedFiles/Rob..._Update_04.pdf
Unread 22-01-2011, 11:45
AKA: Matt Soucy
Yeah, we found that. Thank you!
