Go to Post Joining a FIRST team is the beginning of "smart," not the culmination. - klrswift [more]
Unread 18-01-2011, 21:32
85450 85450 is offline
FRC #0662
85450 is an unknown quantity at this point
Error in mecanumDrive_Polar of WPILIBJ
We determined that the mecanum drive function has an error. Specifically the line
double sinD = Math.cos(dirInRad);
should be
double sinD = Math.sin(dirInRad);
Can someone provide information on how to get this fixed in the WPILIBJ library.
Thanks!
Unread 18-01-2011, 22:07
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Error in mecanumDrive_Polar of WPILIBJ
What we do when this kind of thing happens is just copy the entire FRC supplied class into our package and correct the part that seems wrong. And use the one in our package instead of the one in wpilib.
Unread 21-01-2011, 00:03
bakketti bakketti is offline
FRC #0443 (Freelance Robotics)
bakketti is an unknown quantity at this point
Good catch! This explains why mecanumDrive_Polar() isn't working. Thanks.
Unread 21-01-2011, 09:30
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
I added this as a bug at http://firstforge.wpi.edu/sf/go/proj...ilib_java_bugs as artf1315.
Unread 22-01-2011, 11:52
sfletty sfletty is offline
FRC #2846
sfletty is an unknown quantity at this point
Does the problem exist in mecanumDrive_Cartesian too? We're seeing similar problems.
This is what we're doing:
drive.mecanumDrive_Cartesian(lstick.getX(), lstick.getY(), rstick.getX(), gyro.getAngle());
Unread 22-01-2011, 12:34
I have experienced problems with mecanumDrive_Cartesian too. It actually works when I put a fixed 0 degrees or 180 degress in the angle input. However, other values have not worked for me (from what I remember). I have spent some time trying to figure out the problem. No luck yet. But rotateVector() in RobotDrive is okay. Our team got field relative driving running by using rotateVector() to manually transform coordinates.
Unread 22-01-2011, 18:41
7519534682 7519534682 is offline
FRC #3125
7519534682 is an unknown quantity at this point
Is there any way to get a working mecanum drive until mecanumDrive_Polar() is fixed?
Thanks
Unread 22-01-2011, 18:45
Thanks
You could write your own. It's not that hard. Here's some help.
Unread 22-01-2011, 19:35
MattG_3165 MattG_3165 is offline
FRC #3165 (Newbots)
MattG_3165 is an unknown quantity at this point
Thanks
There sure is, Patrick explained how in post #2:
Unread 24-01-2011, 11:46
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
attatched should be enough to be a better mecanum drive with no black box
http://www.chiefdelphi.com/forums/at...9&d=1295551765
Unread 27-01-2011, 15:11
AKA: Brad
#0190 ( Gompei and the Herd)
should be
Thanks!
You just did get it fixed. Will be in the next release. Thanks for the patch!
Brad Miller
Robotics Resource Center
