Go to Post Start up the rumor mill... - frcguy [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 21-01-2011, 00:26
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Legality of Jaguar closed-loop control modes
Originally Posted by taichichuan View Post
In order to use the Jaguars in one of the closed loop modes, you have to load PID values to the Jag. That would appear to be prohibited by the GDC's ruling.
The jaguar would be in Voltage control mode.
The position (or speed) values can be read through the CAN bus (after the correct settings are loaded into the jaguar, SpeedReference for example).
The voltage to send to the jaguar can then be calculated on the cRio.
This does not use any of the Jaguar closed-loop modes, and so it seems legal.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 21-01-2011, 00:42
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
While it is possible to run PID on the controller successfully, there are substantial advantages of running it on the motor controllers themselves. In particular there is less need to consider timing jitter in control loops or message bandwidth limits if using the Black Jaguar serial to CAN convertor.
But mostly this is a poor decision due to the reason Eric stated above.
