Go to Post Hasn't that always been the mission of FIRST? Don't settle for what works; strive for what amazes. - Sam Lipscomb [more]
Unread 18-01-2011, 16:09
Arthur But' Arthur But' is offline
FRC #2213
Arthur But' is an unknown quantity at this point
Potentiometer use in Labview
Hello.
I just started this year to learn how to work with labview for the FRC competition, and now i understand most of the program.
Nevertheless i still don't understand how to configure the Potentiometer in Labview, also i didn't find any VIs which has anything to do with it.
Basically what we are trying to do is to move the arm, by 3 buttons, so each of them will move arm in a specific angle..... if any one could give me an example of how to operate the Potentiometer in Labview, or if any one would give me a tutorial to it , it would be great!!!
Team 2213 (Israel).
Unread 18-01-2011, 16:27
Re: Potentiometer use in Labview
A properly wired potentiometer provides a variable voltage that is proportional to the angle at which it is turned. Voltages are analog signals, and get connected to the Analog Breakout.
Each set of three pins on the Analog Breakout provides exactly what you need to connect to a potentiometer. Wire one end of the pot to the +5 pin (center). Wire the other end of the pot to the Ground pin. The Signal pin goes to the wiper of the pot. Usually, the wiper is the middle one of three connections on the pot. On a typical PWM cable, Ground is black, +5 is red, and Signal is white.
Read the value using an Analog Get function.
Unread 20-01-2011, 04:58
FRC #2213
Thank you.
Can someone also give an example of how it supposed to look like?
Unread 21-01-2011, 04:37
FRC #2213
Originally Posted by Arthur But' View Post
Thank you.
Anyone?
Unread 21-01-2011, 05:31
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Have you looked in the Example Finder? There is a Potentiometer with Driver Station example. It's not for the robot side of things, but it does show a potentiometer - the wiring idea is the same. I'll look into adding a robot side potentiometer example to the Example Finder.
Doug Norman
Unread 21-01-2011, 08:54
I have a simple example of the basic code side on this page about a quarter of the way down, labeled Analog Input example.
But what you're looking for is probably the PID Example close to the bottom.
That demonstrates the use of a steering potentiometer to position a motor based on the position of a joystick.
For your fixed position arm you'd replace the whole joystick input with just a constant = the exact voltage you'd want the arm potentiometer to read when the arm is where in a fixed position.
You'd have to add a case statement to chose the different values you want the pot to have.
Unread 21-01-2011, 16:28
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
Its pretty easy once you get started, the starting from the example Mark posted, the Analog get returns the value of the potentiometer as a voltage, you can start making this.
You should change the .5 to whatever value you want the motor to run at, and the 2.4 and 2.5 to where you want the motor to stop at which value on the potentiometer, you should also change the way this is done once you get used to PID controls, as this is a really mediocre way to code this, but it works as a proof of concept.
Unread 21-01-2011, 17:33
FRC #2213
Thank you all very much, u helped me a lot
