Thread Tools |
Rating:
Display Modes |
Re: D link wireless bridge
If your laptop has multiple network cards (wireless, Ethernet) the wrong one could be setup. It could be trying to go out over the wireless when it should be using the Local LAN.
I disabled all of them except the lac and it detects the router, but when I hit run as start up in labview it just gives me the failed to connect to real time target error
Make sure your LabVIEW project settings contain the correct IP address for your cRIO. You'll see the target address in parentheses after the "RT CompactRIO Target" line in the Project Explorer window. If it's not what it should be (i.e. 10.30.55.1), fix it by right-clicking and changing the properties.
Yeah it's set to 10.30.55.1 but that doesn't seem to be the problem. It was already like that and I could deploy the code, but it hasn't worked since I set up the router. I am plugged directly into the robot though not the router.
That was a trick question. It should be 10.30.55.02
as in: RT CompactRIO Target (10.30.55.02) |
Thanks for watching my back, Mark.
In order to set up the router, you had to change the IP address of your computer. Did you remember to change it back? You probably want to set it to 10.30.55.6 or higher. |
#7
Yeah this was the problem i had as the 192.168 etc.
