Go to Post Having the foolish belief that you can win a match in which you are completely outgunned will drive you to develop a winning strategy. - OZ_341 [more]
Unread 20-01-2011, 19:49
Us3rNam3's Avatar
Us3rNam3 Us3rNam3 is offline
Is LabVIEW code lighter than C++?
AKA: Tristan
FRC #1625 (Winnovation)
Us3rNam3 is an unknown quantity at this point
Numpad on Driver Station?
would it be possible to use a usb numpad as controller input? If not what would be a suitable substitute for the maximum amount of buttons?
Please and Thank you
DFTBA. NERDFIGHTERIA FOREVER!
J'adore les robo.
Unread 20-01-2011, 23:40
Re: Numpad on Driver Station?
The Driver station software will not recognize anything other than an HID joystick/game controller and the Cypress I/O board.
A numpad will not work.
The Cypress board gives you a lot of input choices, or you can purchase http://www.estoprobotics.com/estore/...d&productId=33
which behaves like a standard joystick.
Unread 21-01-2011, 00:54
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
You can set up a custom input scheme if you don't mind doing some programming. In fact, this way you could use practically any USB peripheral -- easiest, however, would be a keyboard or numpad which requires no libraries.
All the rules seem to have to say about this is that all communications must pass through the driver station. And, intuitively, you should only be able to use your custom controls when the robot is active, in teleoperated mode.
EDIT:
I stand corrected, as per rule 75.
The Driver Station software provided on the FRC website (www.usfirst.org/frc/kitofparts) is
the only tool permitted to collate driver/operator inputs and communicate them to the
ROBOT. The Driver Station software must be revision 01.05.11.00 or newer.
This seems to imply you could send automated information to the cRIO bypassing the driver station. You could even lawyer it, and provide a layer of abstraction and cause a program to send automated information to the cRIO based on operator input! I somehow don't think they'll go for that, though.
Either way, this seems like a pretty stupid misinformed rule to me. Sure, you want everything to shut down when you tell it to, but assuming the driving code is within the predefined functions (except the disabled[...] ones), nothing bad would happen. Even with Murphy's Law, I doubt anyone is that unobservant.
You could perhaps demonstrate safety to an inspector (or just not tell them about it), but I wouldn't rely on it. Alternatively, http://headsoft.com.au/index.php?category=vjoy. That's probably the best option.
Unread 21-01-2011, 08:41
What terrible suggestions
Cheating and ignoring the rules to your own benefit or because you just don't feel like it, is not recommended.
It builds the wrong kind of character...
In these forums please work on making valuable contributions I'm sure you're capable of, that benefit impressionable readers (not just the posters) who don't realize your bad advice could get their robot disqualified, their reputation sullied, and their season ruined.
Unread 21-01-2011, 08:53
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
In addition to flaunting the rules, what purpose would be served by sending automated information from an operator console laptop to the cRIO. Why not just store the information on the cRIO in the first place?
Unread 21-01-2011, 09:48
Here's a serious answer: it's a lot more convenient to modify a file on the laptop. You wouldn't have to power up the robot and have it online in order to make changes.
Unread 21-01-2011, 10:23
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
I just stumbled upon this as well, and think it will be our best option, thanks!
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 22-01-2011, 18:01
FRC #1984
... That was a serious suggestion (also, I wasn't flaunting the rules) ...
It's been said before about how hard it is to convey tone through text. And yeah, it's still hard. Regardless of the tone of my post, however, there is no reason which says I must respect the rules, only I must follow them: If I've read them and considered their purpose, I believe I have a valid claim to calling them ridiculous.
I would still suggest trying the virtual joystick software. In my opinion, it beats having to buy new hardware. Another thing I have a problem with is having to use the input devices they tell me to. I can understand them wishing all driver input to go through the station (though, as I said, it doesn't necessarily need to to remain safe), but restricting it to one type of input is absurd and restrictive.
Unread 22-01-2011, 18:19
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
And I was asking a serious question in response. Alan provided a perfectly valid answer that makes sense.
You can use any USB input device you want. You just have to write the custom USB driver to make it look like a HID joystick or gamepad to the Driver Station software.
Unread 22-01-2011, 18:31
FRC #1984
And I was saying there's no reason why that should need to be done.
Unread 22-01-2011, 18:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
So who should be writing the code to support arbitrary input devices if not the teams? How would you propose supporting arbitrary input devices while keeping the DS software closed source?
Note: This is a serious question, not sarcastic.
Unread 22-01-2011, 18:53
FRC #1984
This has nothing to do with code-writing. If I want some new input device, I have to buy something to use it, and probably some new hardware. If they'd remove rule 75, there'd be no problem (in relation to this post, he'd be able to use his numpad). Just have an inspector verify that nothing has a chance to move during the disabled stage (and no one would probably set it up this way, due to obvious reasons...)
Unread 22-01-2011, 18:56
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
That's my point. If I want some new input device, I have to buy something to use it, and probably some new hardware.
A device driver is software that you write. You don't have to buy anything as far as I am aware.
Unread 22-01-2011, 18:58
FRC #1984
If he wanted to use a numpad/keyboard, he'd have to buy a USB encoder and interface it to the encoder. And perhaps I wish to pre-interpret my USB device's data? There's no provisions for sending it to the robot after that.
Unread 22-01-2011, 19:18
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Even if you could find an inspector with the time, you would need a field to show him/her that. Pretty much every regional I've ever been to, the practice and competition fields are booked quite solid.
