Go to Post The difference between a Tinkerer and an Engineer is that the Engineer will be able to tell you the results before you start. - DonRotolo [more]
Unread 21-01-2011, 11:07
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Team 100 what are you up too?!?!
Originally Posted by Chris is me View Post
So the only thing that has to change is the alliance not letting their HP show up and try to get ranking points.
I see zero cause for alarm as this step is absolutely trivial.
This is trivial, but I think the problem will be getting re-inspected. There is a fine line between quick fixes and quick fixes that warrant a need for re-inspection. I think the problem will be that some teams will make modifications and need to be re-inspected, but neglect to do so.
Unread 21-01-2011, 11:51
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Careful, once you're red-carded once, everyone thinks it's hilarious to red-card you every time they see you after that. Like at your own wedding.
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Unread 14-02-2011, 00:05
skistunts1's Avatar
skistunts1 skistunts1 is offline
AKA: Jake Salzman
FRC #0100 (The Wildhats)
skistunts1 is an unknown quantity at this point
Just to make it clear, Team 100 has no intention of getting ANY red cards, let alone an amount that would be near a limit if there were one. The only reason we posted the question was because a team member was curious about it and we didn't see any harm in posing the question.
team100.org
