Go to Post You should always do CAD no matter how you plan on having parts made. - Garret [more]
Unread 21-01-2011, 11:06
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
Lift System Ideas
Team 3329 is trying to decide whether to use a forkilft based gripper, and a slightly articulated arm, or a personal design of using a parallel bar structure with a simple grip and wrist to pick tubes up and place them at any height (i am personally pushing for this one...). If anyone has other ideas, or expounding on the ones i presented, please share!
This post is meant to provide a simple brainstorming session for teams to share ideas, the more the better!
Unread 21-01-2011, 11:41
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Re: Lift System Ideas
It may be hard using a forklift to place it as those usually have the tube laying flat on the lift
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 21-01-2011, 11:51
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
articulating joints (e.g. 4 bar arm, wrist) are usually easier to build, that's the tradeoff here.
lifts give you a straight vertical motion, while arms give you an arc. decide which is better for you in your situation.
at this point you should choose a design ASAP (tommorow) and start working on designing and manufacturing it.
you can keep on debating ideas for the entire build season, but at some point you should stop, decide, and start building otherwise the quality will suffer and the drivers won't have time to train.
lead your team to a decision that is the best possible one within your manufacturing capabilities and run with that ASAP.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 21-01-2011, 12:32
Dumper FTW 435's Avatar
Dumper FTW 435 Dumper FTW 435 is offline
AKA: Ryan
FRC #0435 (Robodogs)
Dumper FTW 435 is an unknown quantity at this point
My team's going with a lift. We considered the arm, but there are a lot of problems fitting in the 84" cylinder if we wanted to reach the top row. I recommend the lift idea.
Unread 21-01-2011, 13:45
HarveyAce's Avatar
FRC #3329 (CAMBots)
our lift wasn't going to have the tubes lying flat on the lift, the design was to have two spreading lift forks that would hold the tube from the inside... like i said above, im trying to push for a design that we can easily do with parts from the kop, because we literaly have no funds and we are a second year team. we want to be able to reach the top pegs but still be able to get around, and I view the articulating arm poorly, mainly because so many things can go wrong, more points of articulation = more points for error.
We are also a second year team, and too many on the team want to do too much with too little time/funds/parts.
Unread 21-01-2011, 13:46
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
OR a combination of both
Unread 28-01-2011, 18:01
Rey Rey is offline
FRC #3132 (Thunder Down Under)
Rey is an unknown quantity at this point
My team decided on an articulating arm. But after some design time we went with a lift portion to the elbow and an arm That has a wrist like function.
It is a combination of both worlds!
