Go to Post Krispy Kreme and Diet Coke. Accept no substitutes! - dlavery [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 21-01-2011, 13:49
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
setX() not working
Not sure if I should post this here or in the Java section...
I was trying to use setX to set a speed of the motor. I set up the speed and position references. But the Jaguar would not do anything (RobotDrive works fine). I did not set PID and am wondering if this could be the problem. Thanks in advance for your help.
Unread 21-01-2011, 15:33
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: setX() not working
If you have configured the CANJaguar to Speed Control mode, then you must do several things to make it work... Set a speed reference, set the number of codes per rotation your encoder outputs, set the PID values (they default to 0 which will do nothing), then call enableControl().
-Joe
Unread 21-01-2011, 21:19
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
related question: is there a default number of ticks per revolution? I had everything you listed set but that value, and the speed was always reported as 0.0. Tomorrow I'll try setting some arbitrary value (or maybe look up the proper one ).
Unread 21-01-2011, 23:17
Guess what... the default is 0. You must set it.
-Joe
Unread 22-01-2011, 22:50
FRC #1700
Ok, so I set the number of ticks, and setSpeed still does not seem to work. Here's what I've written.
    CANJaguar jag;
    public void robotInit() {
        try {
            jag = new CANJaguar(4);
            jag.setPID(1, 1, 0);
            jag.setSpeedReference(CANJaguar.SpeedReference.kQuadEncoder);
            jag.changeControlMode(CANJaguar.ControlMode.kSpeed);
            jag.configEncoderCodesPerRev(100);
            jag.enableControl();
        } catch (Exception e) {
            e.printStackTrace();
    public void teleopPeriodic() {
        try {
            jag.setX(10);
            System.out.println(jag.getSpeed() + " " + jag.getOutputVoltage() +
                               " " + jag.getOutputCurrent() + " " +
                               jag.getTemperature() + " " + jag.isAlive() +
                               " " + jag.isSafetyEnabled());
During Current or Voltage control, the encoder reads fine. But in Speed control, no signal to drive is sent to the jaguar (light is yellow, both outputs are 0, as is the speed). Is there something I'm forgetting to set? Thanks.
Unread 23-01-2011, 02:45
    CANJaguar jag;
        try {
        try {
            jag.setX(10);
The code looks OK at first glance. My guess would be that your PID constants are too small. Try increasing the P at least to see if that has any impact.
-Joe
Unread 23-01-2011, 09:33
FRC #1700
I forgot to mention that with 100 ticks per revolution, my test rig reaches a max speed of 900 rpm. I'll try P=100 today, along with many other combinations of constants, and get back to you. Thanks.
Unread 23-01-2011, 16:33
FRC #1700
Ok, I found the issue. Instead of doing something like this
jag2 = new CANJaguar(2);
jag2.changeControlMode(CANJaguar.ControlMode.kSpeed);
I had to do this
jag2 = new CANJaguar(2,CANJaguar.ControlMode.kSpeed);
I want to look into switching control modes, since I feel position control would be useful during autonomous, and speed would be used for teleoperated.
Unread 23-01-2011, 16:58
I had to do this
Ah yes... your symptoms reminded me of why your code did not work...
setPID() sets the PID constants for the control mode you are in. The original code you posted will work if you move setPID() below changeControlMode().
-Joe
Unread 23-01-2011, 17:43
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
try {
jag.setX(10);
}[/code]
I am confused. My team is triying to use CAN to control a swerve drive, and most of this makes sense. The System.out.print is what puzzles me. Where does this print to?? Obviously it won't go to the driver station lcd, but how would you go about configuring a laptop (I am assuming that is where it would ultimatly print to, but I am unsure where) so that you can operate the robot and see the System.out.print?
A concerned programmer
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 23-01-2011, 17:47
Assuming you are using NetBeans and Java, it prints to the NetBeans "Output" tab below the Source frame.
-Joe
Unread 23-01-2011, 18:07
AKA: Alex
So if i plug the laptop into the cRIO port 1 and boot the robot I should get all the println?? How would I run the robot from the driver station then??
-Alex
Unread 23-01-2011, 18:13
FRC #1700
I'm using Ubuntu with Netbeans installed there, and have the driver station running in a virtual machine of Windows XP (Remember that any computer can act as the driver station). The println's go to Netbeans. if you have the driver station on a seperate laptop, simply plug both of them into the D-Link (or put one/both on wireless), and run the code from netbeans to get it to display the output. Make sure no IPs conflict!
That makes a lot of sense, since if I were to use different modes, I'd want different PID constants for each mode. Thanks a lot for the clarification.
Unread 23-01-2011, 18:27
AKA: Alex
DUH I cant believe I didnt think of that before. Thanks so much!
-Alex
