Go to Post I was outvoted by conservative teenagers (curse them...). - Rick TYler [more]
Unread 21-01-2011, 14:14
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: pic: First Mecanum Drive
Why are the programmers making this decision? I would think the drivers would make that decision, with the advice and consent of the rest of the team.
Well I forgot to mention in combination with the driver.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 21-01-2011, 15:58
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Make sure your frame is solid. I've heard from teams that have had problems with mecanums functioning properly with even the slightest wobble in the frame. If you use the kit metal, I'd recommend gussets and steel pop rivets instead of the hardware they offer.
Especially with the 6" wheels, the plates can dig into the carpet and prevent strafing and turning. Make sure there isn't any wobble in your wheels!
Unread 21-01-2011, 16:26
Actually, a flexible frame helps keep all the wheels on the floor. If it's too rigid, any deviation from a perfectly flat surface will let one wheel lose traction and control will suffer badly.
What you really want to do is control weight distribution. Try to make each wheel carry the same amount of weight. That will make it a lot easier to keep the wheels spinning the way you want them too.
