Go to Post A game where you don't have control of your robot for long periods of time is no fun (unless, of course you are talking about autonomous :p) - Cody Carey [more]
Unread 21-01-2011, 14:18
Re: Another chapter to the 6WD vs. Mecanum debate
Originally Posted by Oblarg View Post
...the rollers do not move unless you are strafing.
or rotating.
The fact that mecanum is "less powerful" is a common misconception - mecanum is *not* omni holonomic,
Mecanum is fully holonomic if properly coded. All three degrees of freedom can be executed simultaneously with no skidding of the contact patch.
and the only difference in power is the difference in coefficient of friction with the floor between the roller material and the material of your six wheel drive wheels.
If by "power" you mean "maximum force" this is not correct. Even with the same material on the mec and the 6WD, the mec will have less maximum pushing force, as explained in many posts here on CD.
