Go to Post If robotics is bad for you, well then I guess I'm gonna die. At least I'll die happy. - karinka13 [more]
Unread 11-01-2011, 08:44
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
2bkrul is an unknown quantity at this point
Classmate Charger
Where can i find another 2010 Classmate charger for very cheap?
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
Unread 11-01-2011, 09:09
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Re: Classmate Charger
I would check ebay. Don't know if they have them but I have bought an off-brand computer a/c adapter off of there before. Can't say much for the quality of the one I bought (it got a short) but you may have better luck than me. The one I bought did last for a while. So it may work for your six weeks of build season and competition.
David
Team #2829
Unread 11-01-2011, 10:41
Define "cheap".
Following the links from http://www.ctlcorp/go/first I find they cost $42.90 from the source.
Unread 11-01-2011, 21:56
2bkrul's Avatar
AKA: Brandon Krul
Originally Posted by Alan Anderson View Post
Define "cheap".
Our team is on a tight budget...so I'm looking for something that costs less than the source
Team 964 on TBA!
Unread 19-01-2011, 08:48
perlgerl perlgerl is offline
Michelle
FRC #0781 (Kinetic Knights)
perlgerl is just really niceperlgerl is just really niceperlgerl is just really niceperlgerl is just really nice
Any charger with the following specs will work:
input 200-240Vac, 50-60Hz, 1.7A
output 20Vdc 2.0 A
Go visit your local electronics discount store and see what they have. $40 sounds about right, unless you can find something in a surplus discount bin.
Unread 19-01-2011, 08:57
I'm pretty sure mains power in Ohio is more like 120 VAC.
Unread 19-01-2011, 12:39
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
I can confirm that. And it's usually quite close to 60Hz as well.
Unread 21-01-2011, 15:01
Michelle
My apologies for my sloppy fingers and thanks to ayeckley and Alan Anderson for catching my mistake.
The specs written the original classmate charger are:
input 100-240Vac, 50-60Hz, 1.7A
output 20Vdc 2.0 A
