Go to Post if you want to repay us for the omni-wheels, use the money to help out a few rookie teams next year. Buy them batteries or help build them bumpers, anything you see fit will be much better than cash back to us. - AllenGregoryIV [more]
Unread 21-01-2011, 15:55
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: PID Speed Control
Originally Posted by BradAMiller View Post
A new release of Java was just published last night that includes very improved CAN Jaguar classes. Give it a try, should work much better.
Unfortunatly, using the PID control of the Jaguars was ruled illegal by Q&A.
Originally Posted by http://forums.usfirst.org/showthread.php?t=16140
There is no rule that prohibits the Jaguars from reading the values from the encoders, however note that Rule R49 requires that the ROBOT must be controlled by the cRIO. In other words, commands may not originate in the Jaguar or any other controller, they must originate in the cRIO.
As my team was going to attempt a similar setup, would someone mind explaining how to setup closed loop speed control (I am really a mechanical guy who has inherited part of programming this year as the main programming student deemed swerve "too hard"). We are using java and have a operating chassis for the swerve. Currently the software "works" as designed but there are different speeds for each wheel, even when the PWM output is the same to each wheel.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
