Go to Post Education doesn't have anything to do with how much money a person can make. Experience, Perseverence, and Character do. - Jnadke [more]
Unread 21-01-2011, 11:08
Re: D link wireless bridge
Make sure your LabVIEW project settings contain the correct IP address for your cRIO. You'll see the target address in parentheses after the "RT CompactRIO Target" line in the Project Explorer window. If it's not what it should be (i.e. 10.30.55.1), fix it by right-clicking and changing the properties.
Unread 21-01-2011, 16:17
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
Yeah it's set to 10.30.55.1 but that doesn't seem to be the problem. It was already like that and I could deploy the code, but it hasn't worked since I set up the router. I am plugged directly into the robot though not the router.
Unread 21-01-2011, 16:33
Originally Posted by DFZXA View Post
10.30.55.1
That was a trick question. It should be 10.30.55.02
as in:
RT CompactRIO Target (10.30.55.02)
Unread 21-01-2011, 16:43
Thanks for watching my back, Mark.
...it hasn't worked since I set up the router.
In order to set up the router, you had to change the IP address of your computer. Did you remember to change it back? You probably want to set it to 10.30.55.6 or higher.
Unread 21-01-2011, 22:00
Yeah this was the problem i had as the 192.168 etc.
