Go to Post General rule of thumb: "If it moves and it shouldn't, use duct tape. If it should move and it doesn't, use WD-40.":) - ben_0614 [more]
  #76   Spotlight this post!
Unread 21-01-2011, 16:39
Re: How should we wire the photoswitchs?
Originally Posted by tommy0019 View Post
those are the correct place to put them, right(without the jumper)?
It sounds like you put the sensor input on the right pins.
do you have any ideas as to why our robot isn't responding to the sensors?
It might be a programming issue. Do you see the inputs changing on the Dashboard display when the sensors activate?
  #77   Spotlight this post!
Unread 21-01-2011, 16:59
tommy0019's Avatar
tommy0019 tommy0019 is offline
FRC #2957
tommy0019 is an unknown quantity at this point
Yes, the gpio state on the dashboard slot 4 changes when the sesor is over the tape. we just created a whole new robot project with the "robot framework with game code" and it did a pre progammed drive. then we did it it just the "robot framework" and it just did nothing at all.
be back tomorrow. i have to go play in a bsketball game now.
  #78   Spotlight this post!
Unread 21-01-2011, 18:28
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Brown +
Blue -
White (sig) to digital side car
Black nothing
If the Sensor is Green: Sensor is powered, but is to far away to sense. no output on blk or wht.
If sensor is Orange: ON sensor is recieving at least 2.5 times the signal strength needed to trigger and output and green will turn off. May have to adjust the sensitivity adjustment on top of the sensor to get an orange on if already mounted. Do this by placing over reflective surface and adjust until it comes on. Sensitivity is the screw on top. If orange is not on there will be no output on blk or wht.
If sensor is Yellow: the output has been energized meaning it sensed reflective object. becareful most bright objects can be sensed regardless of color.
Typical sensor indication is the following
Green OFF, Orange ON, Yellow OFF over dull surface wht low and blk high
Green OFF, Orange ON and Yellow ON over bright surface wht high and blk low
Hope this helps
  #79   Spotlight this post!
Unread 21-01-2011, 22:06
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
Does that make alternating orange and yellow does that mean that sensor is going on and off or what?
  #80   Spotlight this post!
Unread 22-01-2011, 00:10
Pay attention. It means that you have probably miswired one of the outputs to a power pin.
  #81   Spotlight this post!
Unread 22-01-2011, 07:12
riptide's Avatar
AKA: Jeff
If you have a flashing LED, the sensor has gone in to short circuit protection mode becasue one of the outputs is shorted to ground or it is not wired up correctly. Make sure the black wire is not connected ianything. Make sure the white is connected to the signal pin on the digital side car pwm input and not the + or -. Best way to prevent the shorting out of the black wire is to clip the stripped wire and then wrap it with electrical tape. Inspect the sensor cable for any nicks. I will try and post a quick video by the end of today to show how it works and how to connect it.
  #82   Spotlight this post!
Unread 23-01-2011, 02:06
Thanks for the help guys. Turns out that one of our wires was not fully connected
  #83   Spotlight this post!
Unread 23-01-2011, 23:59
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Brown + (connected to red power connector on PDB)
Blue - (connected to black power connector on PDB)
White to the white wire of a PWM connected to the digital side car
Black nothing
The green LED is on.
No matter where we place the sensor in relation to the gaffer tape, and no matter how we turn the adjustment screw, we never see an orange LED on the sensor.
I've read all the posts in the thread and I think I am doing everything right. Not sure what to try next. Any ideas would be appreciated.
Thanks
The views expressed are mine and should not be construed to represent the views of anyone else.
  #84   Spotlight this post!
Unread 24-01-2011, 07:40
Thanks
That is a good thing. Orange means short circuit protection is coming on. It is possible that you have a defective yellow LED. Check by measuring the white pin as it enters the DSC. It should normally be 5 volts. If not, you may have not powered the DSC. All three LEDs on the DSC need to be on and bright. Have you checked the black output of the sensor?
  #85   Spotlight this post!
Unread 24-01-2011, 08:51
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Black nothing
Based on your description, it would appear that the sensor is bad. With just the brown and blue wired you should be able to get the orange light to come on by spinning the adjustment screw.
My question is: have you tried the other two sensors? One bad sensor is possible, two bad sensors is highly unlikely. Just hook up Brown and Blue and mount them looking down. Ensure the lights change before hooking up the white.
Phil Malone
http://www.GEARSinc.org
  #86   Spotlight this post!
Unread 24-01-2011, 10:41
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Thanks Al and Phil,
My next access to the robot will be Wednesday, will check out both of your suggestions.
  #87   Spotlight this post!
Unread 26-01-2011, 23:06
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
Okay, so I am here with rsisk. When we got to the robot and turned it on, poof! The sensors were giving me an orange light, then went green with distance. Like it is supposed to. After being excited and happy. I notice that after a power restart of the robot, they stopped going orange. Any ideas or reasons why? Nothing had changed from the previous weekend when we first wired them up and nothing changed after giving it that power restart. I am completely stumped on what is going on. No shorts, no PWM connections. Just the power is hooked up.
  #88   Spotlight this post!
Unread 26-01-2011, 23:38
Anyone notice in Team update 5 this addition?
<R60> Solenoid Breakout outputs shall be connected to pneumatic valve solenoids or photoelectric sensors, PN 42EF-D1MNAK-A2 only. No other devices shall be connected to these outputs.
Thanks to some of the discussion here, it was noted that sagging batteries would cause a brown out condition on the sensors. R60 now allows a team to add a 9472 solenoid module connected to the +24 volt output of the PD to power the line following sensors with a regulated +24 volts. Thank You FIRST Engineering for the great find and fix.
  #89   Spotlight this post!
Unread 26-01-2011, 23:46
PhilBot's Avatar
AKA: Phil Malone
Did you calibrate the sensors? If not, maybe it's just changing light conditions or where you have the robot located.
Calibrate the sensors on an appropriate section of floor after putting in fresh batteries.
Phil Malone
  #90   Spotlight this post!
Unread 27-01-2011, 15:03
FRC #2493
I would expect that the light condition shouldn't matter. These are very sensitive sensors. I am going to look into the post before this one. I think that might be the key.
