A Question about rule R11
OK being the end of the 2nd week my team still has no design for the robot some are saying elevator and some are saying just the arm and the last third are saying both.
But i brought up a good question on rule R11 about not breaking the 84' diameter mark now is that from the middle of the robot or is that from the bumpers because I measured it out and from the center it only gives us about 1.5 feet. Now am I wrong and is it from the bumpers? Thanks to all people who help and is any one actually going to use an elevator? (because i know every one is going to use an arm) |
Re: A Question about rule R11
It's all in there.Anyway: Your robot, which does not include bumpers, must at all times fit within an 84 inch diameter right cylinder of infinite height. |
Sorry if I'm just blind i don't see it and neither douse my team. >< this is annoying.
can you tell me which section its in sorry |
You need to have this page on your favorites/bookmark list. This is where the information lives. Second, Look in the complete manual OR the section 4 Robot descriptions. Use the search function of Acrobat to find <R11> or just scroll down a bit until you get there. Third, Read for a while. Fourth, come back here if you're still having problems understanding the rules as they are written. Fifth, read the rest of the document, fortified with whatever beverage(s) will lubricate the process. In N.E. the choice is hot chocolate - don't spill any on the keyboard! I've heard good things about the Dew too. Oh, and I can totally sympathize with your team's design difficulties. It even has a name- Paralysis by Analysis. Coming into contact with it firsthand is a valuable experience for your team members. Even if all your team does is build each of their ideas and they only get as far as the practice fields, they can still have fun, be inspired, and learn a thing or five about engineering. |
I'm pretty sure that the rule was your robot has to fit into an invisible 84" diameter cylinder at all times, no matter where its measured from.
But do read the manual, I tend to be wrong a lot. |
If you want to talk geometrically, consider the projection of your robot, manipulators extended, onto the plane of the playing surface. After doing so, a circle of diameter 84" must be able to contain all the projected lines with none of them crossing its circumference. |
#7
oh i believe i understand now thanks every one
#8
Rule <r11> sayd that the cylinder is 60'' in diameter while playing and before game starts it has to fit in a 28''x38'' rectangle with a 60'' height
#9
The 60" cylinder has been corrected to 84". |
